Excuse to delete my 2016 LML - Page 2 - Chevy and GMC Duramax Diesel Forum
 1Likes
post #11 of 13 (permalink) Old 01-18-2020, 09:46 PM
D_R_C's Avatar
You don’t tell them the actual year of your truck, you won’t get anything that way.
Starting with something like a 2005 Duramax cat back exhaust with 4 bolt flange and a selection of exhaust hangers.
Then if you want something different for the tail section go with a filter back exhaust.
Below is my delete pipe (midpipe only) with flanges and a 17” section to connect to the 3 bolt flange.
I ran my stock tailpipe bugle tip for about 9 years, then went with Diamond Eye filter(less) back 5” SS with 6” vented tip.
My exhaust is in 3 sections with 3 & 4 bolt flanges from downpipe back, of course you’ll need tuning.
Dan
EFILive TCM Duramax Tuner
D_R_C is offline
post #12 of 13 (permalink) Old 02-07-2020, 12:54 PM
God Bless the USA
My 2015 LML with 90k miles is sending off a poor quality def code and it has 45 miles before it takes the truck to 65 mph. Some quick reading indicates it's likely a faulty #2 NOX sensor. Is this something that might be under an emissions warranty? Or should I try changing the #2 NOX sensor on my own? Or consider the maple delete route?! Thanks for any thoughts.
diesel_farmer is offline
post #13 of 13 (permalink) Old 02-07-2020, 02:21 PM
aeblank's Avatar
1800-CANADA?
PMs accepted for corrections. ;-)
Sent from my moto z3 using Tapatalk
2014 GMC Sierra 2500HD Denali
CC/SB, 4x4, Fumoto oil drain valve, GM chrome oval running boards, Fold-a-Cover G4 Elite, Bull Ring Tie Downs
aeblank is online now
