13 LML Wipers Will Not Shut Off - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 01-10-2020, 09:14 AM Thread Starter
Hello,
I have a 2013 Silverado ant the wipers developed a mind of their own. Initially when operating they would not shut off or go into intermittent. I could bump them to max speed and the washer operation seems to be working properly. They would stop mid stroke and then start up again. The problem then rapidly progressed to now they just run and won’t shut off at all. I have to pull the fuse when parked. Luckily it’s raining everyday so then running isn’t that ban while I’m driving.
I have searched but unable to find any info on the lml and newer. Apparently the older trucks has a pulse board but I don’t think mine has one.
Any help would be great.
Thanks!!!!!!!!
Brandon
bostonhoff is offline
post #2 of 5 (permalink) Old 01-10-2020, 11:39 AM
Wiring diagram available at GMUPFITTER.COM. Also review this video:
Ron Nielson
Ron Nielson is offline
post #3 of 5 (permalink) Old 01-10-2020, 06:32 PM Thread Starter
Thanks! Unfortunately I believe since my truck is newer the wipers are controlled by the BCM rather than a wiper module like in the video.
post #4 of 5 (permalink) Old 01-11-2020, 12:41 PM
And so it may be.
I think that I look at the video a little differently than you do. I see someone who has determined how the wiper system was DESIGNED to work, has printed a wiring diagram to look at how the wiper system SHOULD work, and THEN how it could RUN ALL THE TIME. Then with that knowledge, he has done testing to see what parts work correctly, and which don't. He made a determination as to where the problem was, and then fixed the bad part - knowing that he wasn't just guessing. He could have replaced all components with new and would have been covered and spent $$$$. But his effort was to be sure he really found the problem, and then addressed the actual problem.
If you want, you could just replace all the components in your truck (parts shotgun), spend $$$$, and you'll likely have fixed your problem. But if you do some information gathering, get the wiring diagram, do some testing, narrow the problem down to the most likely cause, you will limit your out of pocket $$$$ to maybe $$ or even $. Could your problem be the switch? or the wiring? or the BCM? Or maybe the motor? How will you know?
Your truck, your money, your choice.
Ron Nielson
post #5 of 5 (permalink) Old 01-11-2020, 01:47 PM Thread Starter
Well I appreciate it! Unfortunately I know nothing about electrical. I was able to find a diagram but unfortunately I don’t have the knowledge or ability to read it. I guess I was hoping this was a known problem with this year and model and someone who had experienced the issue knew the fix. Thanks you though!!!
