CP4 FPR Screen with Metal Bits - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 01-10-2020, 11:27 AM Thread Starter
Question CP4 FPR Screen with Metal Bits
New to this forum - appreciate any help.
I have a 2015 Duramax with 82,000 on it. I read about the CP4 issues and decided to replace the FPR with the one from Exergy with better screens. Looking at the old FPR, I found a few small flakes of metal on it - has me really concerned. Question: which side of the screen would be catching debris - the outside you normally see or the inside if you pull the screen off? Thanks for any help.
skimis is offline
post #2 of 9 (permalink) Old 01-10-2020, 07:55 PM
CDmax16's Avatar
Outside
Wehrli intake bridge and AFE IC piping,Edge Insight cts2, AirDog II 165,SDP resonator delete, Mishimoto pcv catch can, MBRP down pipe,Recon led tail lights and third brake light, Morimoto mini D2S 5.0 projectors w/hidís, Morimoto 2stroke 2.0 ledís highs and fogs.
Kryptonite ucaís & tie rod sleeves, CCM diff drop,Fox 2.0 reservoirs, steering stabilizer, CalTracs,
Cognito PISK and heavy duty sway bar links, AirLift bags,
Nitro 4.30ís w/Nitro TracRite posi...
CDmax16 is offline
post #3 of 9 (permalink) Old 01-10-2020, 08:15 PM
rockn69's Avatar
Well then you better replace your fuel pump
2015.5 Chevrolet Silverado LTZ, Z71, SRW.
Summit White
rockn69 is offline
post #4 of 9 (permalink) Old 01-11-2020, 12:30 AM
Same thing with mine when I installed the exergy a few months ago. I also have a 2015 with around 67,000 km at time of install. Found a small flake of something on the screen. I just continued the install and no issues have showed up yet with the CP4.
mwolbaum is online now
post #5 of 9 (permalink) Old 01-11-2020, 01:03 AM
Here's a better pic of mine
post #6 of 9 (permalink) Old 01-11-2020, 09:07 AM Thread Starter
Thanks for the pics. I had the same thing but 10x the amount of debris. Rather than spend 3,500 for a conversion on a truck that trades for 33k I decided to buy a new truck Best of luck with yours - hope it lasts 300k for you.
skimis is offline
post #7 of 9 (permalink) Old 01-11-2020, 06:26 PM
Location: we live in a high mountain valley in the hi country of northern arizona
…. Rather than spend 3,500 for a conversion on a truck that trades for 33k I decided to buy a new truck
Just idily curious. May I be a bit nosy? A bit of background.
I have an LML that I gave $42,000. for little over a year ago (with then 80,000 mi. on it..looked, smelled, ran like a new truck.
Found this site, about wet my pants in fright when I read about the CP-4 issue.
Cost me a bit over four grand to get a "Calif. Compliant" CP3 installed. So my $42,000 truck became a $44,000 truck. Not that is relevant to your post, but after a computer put me on "limp mode" later on I decided to join the "I Hate Live Bunny Wabbet" Fan Club....but that's another story...added another four grand to the cost.
Given all the above...did I save anything? How much, roughly, did you spend for your "new" truck....and what did you get? Mine is a 2013 crew-cab "long bed" dualie. Has some, but not all of the options avail. that year.
2013 3500 long bed crew cab. Purchased at approx. 80,000; at this writing have 93,000+, bone-stock except for a few things to increase reliability - convert to CP3. CAT oil filter with nipple installed. Removed one leaf for smoother ride when "empty" - air-shocks to re-gain correct rear elevation when heavy "bumper-pull" towing. Sold to me with round wheels and round tires. I am happy with round wheels & round tires. Went into "limp mode" at the wrong time. Had the DPF cleaned by a professional DPF cleaning service so pollution system is bone stock and fully operable....well..it was until...Ö..
6686L is offline
post #8 of 9 (permalink) Old 01-12-2020, 09:06 AM Thread Starter
You live in some beautiful country! Seems you are in good shape having done the conversion and that truck should run for a long time. I'm still looking at trucks so can't report on the possible replacement. But your 46k is still a good deal in my mind given how long it will last you vs what a newer truck would cost. Good luck with it!
skimis is offline
post #9 of 9 (permalink) Old 01-13-2020, 04:55 AM
407driver's Avatar
Just MHO, If I found that debris I would immediately change the pump, whether with a CP3 conversion or a new CP4.
The Exergy FPR should save the rest of your fuel system in the event of a catastrophic failure but it could still leave you in the middle of nowhere when it fails without warning. My luck would be not only in the middle of nowhere but with my 5er behind it drastically increasing the problem for me.
Good Luck!
407driver is offline
