Help p262b code. - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 11-25-2014, 08:13 PM Thread Starter
Gbjr08's Avatar
Help p262b code.
My 15 went into regen and started smoking like crazy. I'm getting code p262b. It was doing the same thing before I put the gasket in between the clamp on the downpipe but now that the gasket is there I need some help.
Gbjr08 is offline
post #2 of 9 (permalink) Old 10-17-2015, 10:37 AM
CalDirt's Avatar
Anyone know what P262B means? I had my truck in for some upgrades at my local 4 Wheel Parts and after it came out, I'm getting this code.
2015.5 - GMC Sierra Denali 2500HD CC S/B 4WD LMLGoodies: Edge Diesel Evolution CTS2, Airdog II-G DF-165, Titan 57-gal Fuel Tank, Mag-Hytec Caps, Air Lift Load Lifter 5000 U, Viair Constant Duty OBA, Fabtech RTS 6" lift, Fuel Krank D517 20x10, Toyo Open Country M/T 35x12.5 R20, Bells AND Whistles!
Build thread:
https://www.duramaxforum.com/forum/bu...ld-thread.html
2004.5 - Chevrolet SILVERADO 2500 HD Crew Cab S/B 4WD LT D/A LLY, White
CalDirt is offline
post #3 of 9 (permalink) Old 10-17-2015, 02:48 PM
redwngr's Avatar
Was the battery disconnected during installs?
redwngr is online now
post #4 of 9 (permalink) Old 10-17-2015, 10:05 PM
CalDirt's Avatar
yessum, battery was likely disco'd
Build thread:
CalDirt is offline
post #5 of 9 (permalink) Old 10-18-2015, 11:17 AM
redwngr's Avatar
P262B - Control module power off timer performance
post #6 of 9 (permalink) Old 07-01-2019, 05:30 PM
DuraNole's Avatar
Did you ever figure out the issue for this code? I have the same code and mine won’t start.
2015.5 LML
Fully Deleted with high flow Y Bridge
Lift pump
PPEI tuning with Ezlynk
DuraNole is offline
post #7 of 9 (permalink) Old 11-04-2019, 04:22 PM
cokane1's Avatar
Did anyone have any luck figuring out this code? Have a 2015.5 that shows this code as active/current and won't clear out. Truck spits/sputters at 12k Rail pressure and any kind of load on the engine (i.e. a brake stand or going up a hill)
Thanks
- 2011 GMC DENALI <LML HP/TQ "Record Holder" at 1,420RWHP/2300RWTQ> - Returned to Stock (SOLD)
- 2006 CHEVY LBZ RC/LB (SOLD)
- 2006 GMC LBZ EC/LB (SOLD)
- 2007 CHEVY LBZ CC/SB (SOLD)
- 2007 CHEVY LBZ EC/SB SS FRONT BUMPER (SOLD)
- 2003 CHEVY LB7 RC/LB ZF6 (SOLD)
cokane1 is offline
post #8 of 9 (permalink) Old 12-09-2019, 04:59 PM
deez112's Avatar
Bump.....same here
deez112 is offline
post #9 of 9 (permalink) Old 12-10-2019, 04:38 AM
407driver's Avatar
The ECM is most likely malfunctioning.
Try pulling both negative battery cables and leave them off for 30 minutes or so to see if it resets the ECM.
407driver is offline
