DEF/UREA Check The Date - Page 15 - Chevy and GMC Duramax Diesel Forum
 12Likes
post #141 of 148 (permalink) Old 11-08-2016, 11:36 AM
right, nox sensors. anyway no more problems!!!
RickL likes this.
like11chev is offline
post #142 of 148 (permalink) Old 05-28-2018, 08:25 AM
Duraek's Avatar
I got the DEF fluid bad quality message and it turned out to be a NoX sensor.
Duraek is offline
post #143 of 148 (permalink) Old 05-28-2018, 10:59 AM
chevymec's Avatar
I have found on the bigger stuff I work on, it is a good idea to drain the DEF tank from time to time. Also, a DEF tester is a good thing to have. Just like an antifreeze tester.
2005 Chevy 2500HD LT CCSB
Superchip
Volant CAI
S&B turbo inlet
Stock exhaust
305/55/20 Falken A/T3
Granite All Terrian rims
Bilstein 5100's
chevymec is offline
post #144 of 148 (permalink) Old 05-28-2018, 12:27 PM
1Blue78's Avatar
Antifreeze tester tests for freezing/boiling temps. I haven't seen a DEF tester - what is it testing for?
2017 SRW 3500 SLT Z71 CC
1978 Trans Am, 400, factory 4 spd, 3:42 posi
DEF - saving the environment one plastic jug at a time
oh, and I love fossil fuels...
1Blue78 is offline
post #145 of 148 (permalink) Old 05-28-2018, 03:19 PM
redwngr's Avatar
% urea
The ones that I've seen pics of were refractometers.
Like this one:
https://www.amazon.ca/OTC-5025-Diese...sl_gylhnjyyp_e
NAPA has one looks like an antifreeze tester:
https://www.napacanada.com/en/p/SERTHX108
Muzbomb likes this.
redwngr is offline
post #146 of 148 (permalink) Old 05-28-2018, 04:16 PM
chevymec's Avatar
Originally Posted by redwngr View Post
% urea
Like this one:
We have the napa one. 1 or 3 balls floating past the line is bad. 2 balls is good. Pretty simple.
Sent from my SM-G930V using Tapatalk
Muzbomb likes this.
Superchip
Volant CAI
S&B turbo inlet
Stock exhaust
Bilstein 5100's
chevymec is offline
post #147 of 148 (permalink) Old 09-01-2018, 10:53 AM
Muzbomb's Avatar
I know this is probably old new but I always try to run my DEF down low as I can just to ensure that what is in my DEF tank gets used up before I put in the new product. I know a guy that bought a semi that sat for a while bank repo and he got it was checking it over and the whole inside of the DEF tank was a solid white crystal so that’s when I started to run my DEF down low as I can just to ensure the older stuff gets used up have 136,000km now and not one issue”knock on wood” ✊🏻😊
2016 Chevy 2500HD: ready lift leveling keys with 1" blocks in rear, Flo Pro 4” NM, EGR blocker plates, Autocal with Mitch Cooper tunes/trans tune, CCV delete, Edge CTS2 monitor with EGT probe, 40” RC curved light bar mod in bumper, LED 45w headlights and fog lights, white Recon LED cab lights, LED switch back side tow mirror lights, Trex grille inserts, rear husky plastic wheel well liners, custom paint match mirrors, tow hooks and bow ties, Rough Country HD2 side steps, winter tires ultra 20x9" rims with 33"Goodyear dura trac studded, summer tires Mayham Arsenal 20x9" with 35" Comforcer tires
Soon to come in spring 5”RC lift!!!
Muzbomb is offline
post #148 of 148 (permalink) Old 05-04-2019, 01:20 PM
TylerLouviere's Avatar
I have a solution, delete delete delete
2005 GMC 2500HD LLY CC SB 6 inch lift
2012 GMC 2500HD DENALI LML 7.5 inch lift
TylerLouviere is offline
