Check your wiring guys! - Page 2 - Chevy and GMC Duramax Diesel Forum
 9Likes
post #11 of 42 (permalink) Old 06-15-2016, 09:22 AM
PhatMateo's Avatar
Thanks @Cameo, that's what I was thinking the solution was. I'll be checking mine this weekend. I haven't had any issues yet regarding this. Thanks for posting your findings!
2011 Denali HD 2500 CCSB, Pypes Down pipe, Sulastic shackles. Constantly building the truck in my head, but never buy anything for it.
PhatMateo is offline
post #12 of 42 (permalink) Old 06-15-2016, 09:23 AM Thread Starter
I found that disconnecting the affected wire harnesd and running it back behind the larger orange wire harness then back over and re-connecting achieves the goal of moving it away from the metal AC line it is shorting on. Did not have to zip-tie.
Better to address the issue before it becomes a problem. Trust me its no fun when the motor just randomly shuts down going down the road
cfell likes this.
Sandman_73 is offline
post #13 of 42 (permalink) Old 06-16-2016, 08:04 AM
Cameo's Avatar
I tried to disconnect it and I couldn't get it done. It was hard to see on the backside how to un-clip it. I said screw it and zip tied it. It looked like the other wiring harness in the conduit should be clipped to the A/C line. Mine was not clipped to it so I clipped it back on to the A/C line.
Cameo is offline
post #14 of 42 (permalink) Old 06-19-2016, 09:17 AM
gdm
Thanks for the tip. Checked my truck and sure enough it was in the process of rubbing through. Zip tied it and all is good for now.
As it happens I found another wire harness rubbing on the upper control arm on the drivers side just the other day and had zip tied it up out of harms way so the rest of you may want to check for this one as well.
2011 GMC 2500HD Crew 8'
gdm is offline
post #15 of 42 (permalink) Old 06-19-2016, 09:53 AM
Ditto, mine was starting to rub thru. Maybe if the hard black plastic stuff was used instead of the fabric type this wouldn't have been an issue. Zip tied away. I'll have to check the drivers side upper control arm next
SuperBlackTruck is offline
post #16 of 42 (permalink) Old 06-19-2016, 03:25 PM
Cameo's Avatar
Photos anyone?
Cameo is offline
post #17 of 42 (permalink) Old 06-19-2016, 07:25 PM
I found mine was rubbed through the silver heat tape and the plastic loom in one spot near the egr cooler. Removed the heat tape and loom to inspect wires , all was well. So re taped it up and will keep an eye on things.
2012 Lml CCSB Chevy LT Stock
brad6 is offline
post #18 of 42 (permalink) Old 06-21-2016, 05:13 AM
Can someone get a wider shot of where this is? I can't seem to find the wires based on the photos posted. Thanks
2011 GMC 2500 HD Leveled, EGR delete. 5" FloPro exhaust with FTE resonator. MBRP downpipe. PPEI ECM and TCM tunes by Kory. S&B intake. Resonator delete. PCV reroute. Edge CTS with pyro. Fass 150 w/ Beans sump. CP3 conversion, SDP intercooler pipes.
Volnut is offline
post #19 of 42 (permalink) Old 06-21-2016, 07:25 AM
Cameo's Avatar
Here is a higher view. To the left of the orange conduit you see a aluminum fitting for the A/C compressor that has a bar code on it. In my picture you see small black conduit that goes up and over that A/C line. Right behind where the A/C line goes down to the A/C compressor is where you will find the rubbing on the A/C line.
Volnut likes this.
Cameo is offline
post #20 of 42 (permalink) Old 06-22-2016, 04:51 AM
Thank you @Cameo!
Volnut is offline
