Hard down shift while coming to a complete stop - Page 2 - Chevy and GMC Duramax Diesel Forum
 3Likes
post #11 of 34 (permalink) Old 11-09-2016, 09:20 PM
I have had the bowling ball rolling to the front of the bed sound on occasion. I think it's just the transmission learning
Sent from my SM-G920V using Tapatalk
South Florida GMC
2011 GMC LML CCLB SLT DRW 4x4
285/75/R17 B & W turnover ball
Antitheft hose clamp installed on tailgate hinge
109,000 first cp4 replaced along with most of fuel system Airdog 165 added + Stanadyne Summer Formula
GM DRW Member #256
"The NOx Sensor is on the way out when you drive it out of the lot"
SouthFloridaGMC is offline
post #12 of 34 (permalink) Old 11-10-2016, 07:27 AM
This has also happened to mine a few times following.. Feels like I ran something over or hit something first time it happened I had to back up thinking I ran over or hit a sign..
strokedblaster18 is offline
post #13 of 34 (permalink) Old 11-10-2016, 07:34 AM
Back in 2004 I had this happening on a couple of my trucks. My local GM mechanic removed the driveshaft and lubricated the splines on the output shaft of the transmission. That stopped it.
Not sure if yours is the same issue but might be worth a try.
27 Duramax's so far!!
www.ProFabPerformance.com
We also handle S & B filters, Air Dog lift pumps, and Kraftwerks Superchargers.
Special Thanks to my Sponsors!!
Danville Performance, SoCal Diesel, Vibrant Performance, & ProFab Performance!!
RickDLance is offline
post #14 of 34 (permalink) Old 11-10-2016, 08:24 AM
DuramaxForum Guru
jc1843's Avatar
Most likely the additional 300 RPM, when in regeneration mode, is causing the hard downshift.
For a test-- in a safe area, try holding the RPM 300 RPM higher and come to a stop using your left foot.
My LLY does this on the first few stops, when trans is cold.
jc1843 is offline
post #15 of 34 (permalink) Old 11-12-2016, 11:20 AM
Had my 2015.5 for almost a year now. Experienced the same thing from day one. I pay pretty close attention to things going on with my truck and I've finally concluded that the issue seems to only occur during a regen with the idle running about 300 rpm higher. Looks like others are experiencing the same issue.
strokedblaster18 likes this.
2015.5 Chevy Duramax 2500HD
bzeller is offline
post #16 of 34 (permalink) Old 11-13-2016, 07:19 AM
NachO_GMC's Avatar
Same here - only when in regen - it's a thud into first and you really can't avoid it, just need to be ready for it.
I'm honestly used to it, you can tell when the thing is in regen, soft power and it's lazy feeling, not to mention that extra 300 or so rpm at idle.
2017 3500 Chevy High Country HD
2015 3500 GMC Denali SRW - Sold 2/5/2017
NachO_GMC is offline
post #17 of 34 (permalink) Old 11-13-2016, 09:18 PM
MRTQ's Avatar
My 2015.5 would do it on the first three downshifts after the start of a regen, it's like the the ECM forgot to tell the TCM that is has raised the engine idle. After the first three downshifts, it would figure it out. Scared the SH out of me the first time it did it. I don't have those issues anymore now
SouthFloridaGMC likes this.
MRTooQuick- Deleted and Tuned 2015.5 CC DRW 3500 LTZ + Package. Summit White with Cocoa / Dune leather Interior. VLEDS Throughout.
MRTQ is offline
post #18 of 34 (permalink) Old 11-13-2016, 09:50 PM
Are you saying the issue went away completely or that you're just not scared SH'less anymore when it does happen?
bzeller is offline
post #19 of 34 (permalink) Old 11-14-2016, 09:29 AM
MRTQ's Avatar
I am saying that since my truck no longer regens, it is not an issue for me :-)
MRTQ is offline
post #20 of 34 (permalink) Old 11-14-2016, 09:38 AM
Well aren't you just special. I'm envious!!!
bzeller is offline
