CP4 Exergy " System Saver " Fuel Pressure Regulator Install - Page 2 - Chevy and GMC Duramax Diesel Forum
 108Likes
post #11 of 152 (permalink) Old 04-27-2018, 09:33 PM
Engineered Diesel
Anyone have experience with this?
AlisoBob is online now
post #12 of 152 (permalink) Old 04-27-2018, 09:41 PM Thread Starter
shortnugly's Avatar
Pull the coolant hose off the intercooler but you'll need a way to stop this up. This one was a small gusher. I had a siphon hose ready though. If you drain coolant out of the radiator before you start, you'll still get some leakage just not as much.
My jiggle siphon hose worked great.
Orezona likes this.
2015 Denali HD
Airdog II 165 Lift Pump
RC Leveling Kit
Toyo Open Country AT II
Exergy FCA / MPROP
Edge CTS2
Fragile CP4
shortnugly is offline
post #13 of 152 (permalink) Old 04-27-2018, 09:47 PM Thread Starter
shortnugly's Avatar
Now, with the A/C compressor gone. You have a ton more access to the FPR. Zip tie the thermostat coolant line out of the way.
Orezona likes this.
2015 Denali HD
RC Leveling Kit
Exergy FCA / MPROP
Edge CTS2
Fragile CP4
post #14 of 152 (permalink) Old 04-27-2018, 09:53 PM Thread Starter
shortnugly's Avatar
Pull the Di-Lithium Crystal pack housing out of the clip and the flux core harness out of the way. This is a little known secret among LML owners.
This pic is out of sequence. It can be moved at any time when you're disconnecting the coolant hoses.
Orezona likes this.
2015 Denali HD
RC Leveling Kit
Exergy FCA / MPROP
Edge CTS2
Fragile CP4
post #15 of 152 (permalink) Old 04-27-2018, 10:01 PM Thread Starter
shortnugly's Avatar
There's that little F&@*ker ! FPR is now more visible. Shot looking straight down at it. That fuel line right next to the arrow prevents a 1/4 extension from seating your Torx bit onto the bolt in a level and straight manner. That's why a thinner Torx extended bit is useful. Especially when you're re-installing it and you need the bolt to start straight in and not cross-thread.
Name:  MPROP Install 7.jpg
Orezona and DilleyDilley like this.
2015 Denali HD
RC Leveling Kit
Exergy FCA / MPROP
Edge CTS2
Fragile CP4
post #16 of 152 (permalink) Old 04-27-2018, 10:11 PM Thread Starter
shortnugly's Avatar
Another shot from the A/C compressor area. You can see the puddle of coolant around the base of the FPR where it seats on top of the fuel pump. Take time to wipe around the FPR as best as you can and blow out the coolant with your air compressor gun. Try to get this so no loose crap falls in to the pump when you pull the FPR.
**** Danger Will Robinson! Anything that falls into the top of the pump will get sent to your injectors *****
Pull the connector off and remove the two T25 Torx bolts.
Orezona likes this.
2015 Denali HD
RC Leveling Kit
Exergy FCA / MPROP
Edge CTS2
Fragile CP4
post #17 of 152 (permalink) Old 04-27-2018, 10:18 PM Thread Starter
shortnugly's Avatar
Gently pull the FPR straight up once both bolts are free. Take care not to drop one into the abyss of the engine's valley. If you do, you can either try to fish it out with a magnet or just go buy a new stainless steel one.
Here's the OEM FPR out. Single 80 micron screen.
Orezona likes this.
2015 Denali HD
RC Leveling Kit
Exergy FCA / MPROP
Edge CTS2
Fragile CP4
post #18 of 152 (permalink) Old 04-27-2018, 10:19 PM Thread Starter
shortnugly's Avatar
Exergy FPR. Dual 20 micron screens
Orezona, 407driver and idtuner like this.
2015 Denali HD
RC Leveling Kit
Exergy FCA / MPROP
Edge CTS2
Fragile CP4
post #19 of 152 (permalink) Old 04-27-2018, 10:21 PM Thread Starter
shortnugly's Avatar
My DeWalt 6 inch T25 bit. $5.87 at Home Depot.
Orezona and Muzbomb like this.
2015 Denali HD
RC Leveling Kit
Exergy FCA / MPROP
Edge CTS2
Fragile CP4
post #20 of 152 (permalink) Old 04-27-2018, 10:24 PM Thread Starter
shortnugly's Avatar
Used it on the end of my magnetic extension. Total extension was 8.75"
Orezona and 407driver like this.
2015 Denali HD
RC Leveling Kit
Exergy FCA / MPROP
Edge CTS2
Fragile CP4
