High Mileage Reports - With Stock Cp4 - Page 11 - Chevy and GMC Duramax Diesel Forum
 53Likes
post #101 of 133 (permalink) Old 11-11-2019, 08:29 AM
D_R_C's Avatar
Heck, even todayís generators will set a code and flash a set of numbers if it has issues, you should know this.
Todayís vehicles doesnít do that my 86 did, you need devices to try to trouble shoot.
You also might consider laying off the ether on the newer diesels since about 2003, itís not suggested.
Heck, you should know this as well.
Dan
EFILive TCM Duramax Tuner
Donaldson 550832 2 qt oil filter
D_R_C is online now
post #102 of 133 (permalink) Old 11-11-2019, 06:02 PM
rockn69's Avatar
Originally Posted by mizterwizard View Post
If you have a truck with only 10K on it you probably don't have a CP4. The newer trucks have an HP4 which is more closely related to the CP3 than the CP4 in design. Was that a typo for 100K or did you find a really low mileage truck?
How do you figure a 2016 would have a Denso HP pump?
2015.5 Chevrolet Silverado LTZ, Z71, SRW.
Summit White
rockn69 is offline
post #103 of 133 (permalink) Old 11-11-2019, 06:16 PM
Using ether is like frying bacon while yer naked.
They say you shouldn't, but if you're careful it works.
Don't tell the cook that she shouldn't cook naked 'til after breakfast.
dmarriner60 likes this.
On my third DMax.
578VTR is offline
post #104 of 133 (permalink) Old 11-11-2019, 06:29 PM
Originally Posted by TheFickler View Post
I'm looking to hear from who out there has some higher miles and have not had any issues with their Cp4?
I've currently got 32,000 on my '16, but im tossing around the idea of trading it in next year before the new HD comes out, and getting an '18 with the LP5. I'm just trying to decide on if I want to stick with the grenade under the hood or trade up to the LP5. A Cp3 swap isn't out of the question either, but I'm hard pressed to put that kind of money into an already expensive truck just to make it more reliable.
Just looking to see who has taken the gamble and beat the house!
So Im in an 18 GMC. Bought new off lot with 9 on odo. Previously sold my 13 2500 LT Duramax.
This is the biggest POS I've seen in awhile and I plan to dump it ASAP. It is absolutely no comparison to my 13 LML in most every department. Briefly:
Shocks gone at 35k
Brakes suck
Dead pedal
Weak battery
Paint chips if you look at it
Tailgate wont open even with key
And the Allison...its failed to unlock at a stop a few times nearly vaulting me in to fixed posts at stores and such. It does ultimately release with a bang. Done this 5 or 6 times since new. Got a few slap shift chirps without asking too.
And the frigging ball joints are banging just like the 13 with 225k. Sure I grease them and it stops for few hundred miles but then its back. All this at 40k miles.
This is a 18 SLT and the 13 was an LT. Both are in oilfield service. The 13 needed 2 sets of batteries and 4 sets of tires, thats it.
This one is headed for Carmax or private sale before she reaches 48k and filed under "lessons learned ".
My experience and my rant...over. ( Still want one ? )
18jimmy2500 is offline
post #105 of 133 (permalink) Old 11-11-2019, 06:52 PM
D_R_C's Avatar
No problem, it’s your motor.
I know your a master mechanic from the late 70’s, I was building race motors in the late 60’s while you was teaching 10 years later.
I’d just soon the cook not frying my bacon while naked, I’m not a fan of pubic hair in my food.
New with 9 posts and knowing everything, just what we needed.
By-by
Dan
D_R_C is online now
post #106 of 133 (permalink) Old 11-11-2019, 09:32 PM
dmarriner60's Avatar
Easy DRC you are the only one on attack he was just telling us his milages and experiences when I read it. Your getting off topic
Sent from my SM-G970U1 using Tapatalk
2012 Graystone Metallic CCSB 6.6 LML
Work in Progress
dmarriner60 is offline
post #107 of 133 (permalink) Old 11-11-2019, 10:00 PM
SilverGorillaLML's Avatar
I have no dog in this fight but i will say this. With glow plugs and grid heaters it will ignite with ether before the piston is at tdc. Normal ignition starts when the piston is just before tdc so having it ignite before could bend rods, damage rings and pistons. If you are going to use it, disable the glow plugs.
D_R_C likes this.
Race/Pulling truck:2012 Cummins/Built 6.8L/Big air/Big fuel/48RE Swap/PCS 2000/B&M Gated shifter
Playing eye spy for another duramax
SilverGorillaLML is offline
post #108 of 133 (permalink) Old 11-12-2019, 06:30 AM
No problem, itís your motor.
I know your a master mechanic from the late 70ís, I was building race motors in the late 60ís while you was teaching 10 years later.
Iíd just soon the cook not frying my bacon while naked, Iím not a fan of pubic hair in my food.
By-by
Look,
I have followed this forum for several years and the body of information here has saved me some misery from time to time. The specifics on given problems have saved a lot of blind troubleshooting.
I joined hoping to maybe give something back to the guys who are generous with their time and knowledge, or maybe help someone who is new to the game.
The only reason I noted my experience at wrenching is that I found this post kinda condescending...
To be honest owning a diesel requires a little more responsibility to know whatís going on compared to just owning a Prius.
Edge Insight ďmonitor onlyĒ would be a good investment that you can even take with you to put in another truck, this way youíd have ideas on whatís happening or whatís not happening.
I'm active on a few other forums and recognize some personality types. While I don't take myself very seriously and try to find humor in most situations, I won't be bullied either. At this point, to save some snarky exchanges, why don't you put me on ignore.
There are a lot of things in this world that "aren't recommended" like using ether. When someone is 90 miles from nowhere and his truck won't start, very carefully using a little squirt is better than a long walk. Instead of giving me grief for using it, finding out HOW I used it would be of more use to the guy sitting in the woods with a dead truck.
Thank You
On my third DMax.
578VTR is offline
post #109 of 133 (permalink) Old 11-12-2019, 08:18 AM
D_R_C's Avatar
Thank You
Dan
D_R_C is online now
post #110 of 133 (permalink) Old 11-12-2019, 08:28 AM
D_R_C's Avatar
Off topic was attempting to warn him on the dangers using ether on these diesels.
But being a former high school auto teacher in the 70ís, we get a stupid reply about cooking bacon naked, because he thinks he knows it all 50 years after.
Maybe research the subjects before he embarrasses himself again.
Thatís ok, after that that new guy with limited knowledge made my ignore list.
Dan
D_R_C is online now
