LML Plugged DPF or bad injector / CP4 issue - Page 2 - Chevy and GMC Duramax Diesel Forum
 2Likes
post #11 of 15 (permalink) Old 08-10-2018, 10:21 AM Thread Starter
Originally Posted by Cornach View Post
The DPF warranty is 8/80. Should still be within 8 years. I would check the in-service date
I believe it 5/ 50 can’t find anything besides if you live in Cali you get 7/70. Is there something I missed ? Cause this could help
2016 GMC Denali 2500 CC/SB
Bought used at 9k. Full Delete at 14K.
Wehrli CP3 Conversion, exergy sportsman pump.
Fass 95 with draw straw, MBRP 3" SS Down pipe, Flo-pro 4" strait pipe, Deviant up pipe, Stock intake and plumbing, Motor OPS Single tune Stock with CTS2. Allison Deep pan with Trasynd.
DmaxDan66 is offline
post #12 of 15 (permalink) Old 08-10-2018, 10:37 AM
Cornach's Avatar
On the LML exhaust the DPF is part of the SCR. The feds mandate that the catalytic converter on any vehicle (which the DPF/SCR falls under) be warranted for 8 years or 80,000 miles.
I went through this a couple of years ago when my 9th injector failed and plugged the DPF. The dealer wanted $3500.00 for the repairs. I reminded them about the 8/80 catalyst warranty so they covered the DPF and charged me $586.00 to replace the 9th injector, 2 months later I got a letter from GM stating an extended warranty on the 9th injector for 10/120, I brought the letter and the receipt to the dealer and they reimbursed me the $586.00
Cornach is offline
post #13 of 15 (permalink) Old 08-10-2018, 10:41 AM Thread Starter
Thank you for the info !!!!! I will let him know
post #14 of 15 (permalink) Old 08-10-2018, 11:26 AM
Cornach's Avatar
No problem, Let us know how he makes out?
Cornach is offline
post #15 of 15 (permalink) Old 08-15-2018, 10:57 PM Thread Starter
Little update! So putting water in the dpf. Well after drying in the sun and trying to blow it out with a leaf blower there is still water in there. When we started the truck after putting it back on it stopped regening and idled normal seems to run ok but the dpf pressure sensor says 1500 psi when before it read 80psi. My friend only has 18 months left on his after market extended warranty so he is canceling it and getting 2k back. The dealer won’t budge on a new dpf which they way 4K for. Since there is only 18 months left of warranty he is just gonna delete it. He is gonna do a full delete and cp3 conversion since he would be spending the 4K anyway.
