Oil in the intake on my lml - Chevy and GMC Duramax Diesel Forum
 3Likes
post #1 of 27 (permalink) Old 04-07-2019, 10:25 AM Thread Starter
Hello,
I was putting some def in my truck and noticed there was a little oil around my intake temp sensor, I pulled the hose off to take a look and there is an oily residue inside the hose and on the throttle valve plate. Is this an issue and what causes it.
Cope9000 is offline
post #2 of 27 (permalink) Old 04-07-2019, 03:41 PM
Riley 1820's Avatar
It's caused by the pcv. If there is enough build up it can cause the trubo to get out of balance. Alot of us get a pcv reoute kit. Check the vendor section. Kit is cheap. Also a lot of people get the resonator delete as well.
2012 3500hd srw 4 wd EFILive cp3 conversion dsp5 Jamco exhaust Blue Ridge Diesel lift pump Trifca bed cover
Riley 1820 is offline
post #3 of 27 (permalink) Old 04-07-2019, 04:23 PM
LHN...We ARE the Joneses
Residue, yes.
Unlikely any measurable accumulation, not with the massive volume of air being pushed thru from the turbo.
Not sure what unbalanced issues there would be, downstream of the turbo.
Hook'em_Horns! is online now
post #4 of 27 (permalink) Old 04-07-2019, 11:06 PM
SilverGorillaLML's Avatar
Just reroute the pcv and clean the ic tube etc.
My name is Nic
2011 GMC Sierra 2500 CCSB LML,
Lil ole single s400, fuel,
supporting mods,
rancher tuned,
Various parts from SDP, WCFAB, LDS, DHD
Wiles Diesel Performance
Woodstock, Va
Contact me For Unleashed Duramax Tuning
[email protected]
post #5 of 27 (permalink) Old 04-07-2019, 11:16 PM
Riley 1820's Avatar
If there is enough oil residue on trubo blades dust can collect on them, this is what can cause unbalanced condition. Yes I cleaned residue and rerouted pcv.
post #6 of 27 (permalink) Old 04-08-2019, 05:09 AM
Where would the 'dust' come from, aft of the air filter element?
AlisoBob and eli_harper13 like this.
post #7 of 27 (permalink) Old 04-08-2019, 12:58 PM
Riley 1820's Avatar
I guess I been around trucks that an't prefect. Cause I have seen dust get past air filter.
post #8 of 27 (permalink) Old 04-08-2019, 01:31 PM
Just so I understand. You have owned trucks with dirt getting past the filter and did not investigate to where it was coming from, or attempted to stop it?
LMLLover is offline
post #9 of 27 (permalink) Old 04-08-2019, 01:39 PM
J83
J83's Avatar
technically he did not say he owned the truck but i agree, there are bigger issues at that point than turbo dust buildup lol.
To the OP, yes, some oil accumulation inside the pipes is normal, as stated it is residue from the PCV system that gets re-routed into the intake to be burned in the engine to reduce hydrocarbon emissions from the truck. First gen duramax engines dumped this waste gas to the atmosphere instead of ingesting it. I just pulled the intake off my truck, i can snap a picture of the throttle plate and grid heater if you want to compare.
TCM & ECM Tuning by MotorOps
Y Bridge delete with SS up and down pipes
4" MBRP downpipe back exhaust with muffler
J83 is online now
post #10 of 27 (permalink) Old 04-08-2019, 01:49 PM
If its building enough oil/dust/whatever up on the compressor wheel you have bigger problems. It would take quite a bit of oil or dust to make the wheel to become unbalanced to the point of affecting the shaft and causing it to contact the cover.
My name is Nic
supporting mods,
rancher tuned,
Woodstock, Va
[email protected]
Similar Threads
please help have an oil cooler and about to do an oil change how much oil? hummerh1 General Discussion 8 01-14-2014 01:09 PM
Low Oil Pressure...Fuel in oil...Metallic particles in oil spdracer71 01-04.5 LB7 Duramax Powertrain 21 01-08-2014 03:27 AM
Oil Level High, Oil Pressure High Low Oil Warning Light On DuraMike 07.5-10 LMM Duramax Powertrain 10 01-07-2012 07:47 AM
