Blue DEF elimination/delete - Chevy and GMC Duramax Diesel Forum
 3Likes
post #1 of 11 (permalink) Old 05-02-2019, 07:03 PM Thread Starter
Question Blue DEF elimination/delete
We are looking for a good tuner/programmer device that can delete the DEF system. We would like to keep the original/stock exhaust system with emmission control. Only the DEF system should be deactivated. Does anybody know an address in Arizona/Utah/Nevada where we can get this done or a system/tune (brand) that works well? Thanks for your help!
Buddhie is offline
post #2 of 11 (permalink) Old 05-02-2019, 07:10 PM
Ridge runner tune
2014-GMC 2500 SLE
18"TOYO AT/2
WESTIN BULL BAR
AFE ELITE INTAKE
FASS 95 LIFT PUMP&BEANS SUMP
FIRESTONE AIR BAGS
RAPTOR BED LINER &R/WHEEL WELLS
XDM-45
skw774 is online now
post #3 of 11 (permalink) Old 05-03-2019, 07:15 AM
SheeB's Avatar
Has this actually be done and still have regens being completed successfully to keep the DPF emptied?
_____________
2012 LML CCSB Deleted w/Motor Ops tuning, 5" Flo Pro w/3" DP.
SheeB is offline
post #4 of 11 (permalink) Old 05-03-2019, 08:24 AM
DEF is burned to achieve the regen. So dont think that its possible. They don't have a 9th injector like previous years. So delete all of the DPF system or none.
2005 Silverado 2500, Crew Cab Short Bed. 122,000 miles
MODS: AFE intake, LBZ mouth piece, MBRP cat- less exhaust.
DailyDmax is online now
post #5 of 11 (permalink) Old 05-03-2019, 11:59 AM
redwngr's Avatar
No.
DEF is not 'burned for regen'.
Regen process uses diesel, pumped thru the 9th injector, to heat the exhaust to achieve cleaning soot from the DPF
DEF is injected, by a def injector, whenever the truck is running.
It is used in a chemical process, to eliminate/reduce the NOx emissions.
LML ('11-'16) and L5P ('17+ ) have both a def injector and 9th diesel injector.
LMM ('07.5 - '10) did not use DEF (NOx allowable was higher) and instead of the 9th injector, the injected extra fuel during the exhaust stroke to make the extra heat when regen was required.
J83, eli_harper13 and Twenty4Pack like this.
redwngr is online now
post #6 of 11 (permalink) Old 05-03-2019, 12:04 PM
No.
Guess I shouldn't comment on things I don't understand. That makes sense now thanks for correcting me.
post #7 of 11 (permalink) Old 05-03-2019, 12:19 PM
J83
J83's Avatar
a single EFI live tune would delete the truck and you could leave everything on it except the DEF. as far as i know there is not a tuner out there that can partially disable the emissions.
J83 is online now
post #8 of 11 (permalink) Old 05-03-2019, 04:47 PM
SheeB's Avatar
My buddy had a thought that maybe in the future could work?
What if there was dummy sensors plugged in to replace factory sensors that could be report expected values so the truck would not know any different?
_____________
SheeB is offline
post #9 of 11 (permalink) Old 05-03-2019, 04:51 PM
Thatís the way I thought they would jailbreak the 2017 +.
MIkey52 is offline
post #10 of 11 (permalink) Old 05-03-2019, 05:02 PM
J83
J83's Avatar
you would just be replacing one expensive, problem prone and highly complex system, with a highly complex system that is virtually untested. Deleting the truck is a less complicated solution to achieve the same results. Why do you want the truck to regen anyway? You wont pass testing with the DEF disabled anyway so im not sure i understand the point.
J83 is online now
Similar Threads
EGR down pipe elimination? LazyD 06-07 LBZ & LLY Duramax Powertrain 7 11-14-2018 05:44 PM
looking for advice on complete dfp/def elimination dingo113 Performance Upgrades 2 08-22-2017 07:29 AM
Stock fuel filter elimination?? skidooxman Aftermarket Mods. 7 03-07-2015 01:40 PM
DPF Elimination w/ Black Box Addition Fooling Regen ECU Call lone Ranger 07.5-10 LMM Performance Parts Discussion 3 02-12-2008 11:14 AM
