Need Help - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 07-01-2019, 04:26 PM Thread Starter
DuraNole's Avatar
Need Help
Cranked truck and idled for about 2mins, then just shut off. Didn’t throw any error codes, now it won’t crank. Had a Mechanic buddy check with scanner and found a P262B code. Tried resetting error and cranking. No go, code will not stay cleared. Truck is a 2015.5, fully deleted with high flow Y bridge, Fass 150 lift pump. Any help would be great! Checked all fuses, good.
2015.5 LML
Fully Deleted with high flow Y Bridge
Lift pump
PPEI tuning with Ezlynk
DuraNole is offline
post #2 of 6 (permalink) Old 07-01-2019, 09:35 PM
I have had that on dodge's and they never had a no start. From what I know that just means their time is bad to run certain tests they need to run. I have never had one not start a truck. Did you check your primer? I am not thinking that is your problem unless you have good fuel pressure. You said you have a fass do you have a pressure gauge in the truck or a mechanical one you can hook up? Also try another key those stinking things go out on a whim with no warning. But if that's the only code your throwing and it cranks fine just wont start I would lean towards your ECM pooped its pants and that's no bueno but I like to check everything before condemning those high dollar computers hope you figure it out
ChevyCowboy2013
ChevyCowboy2013 is online now
post #3 of 6 (permalink) Old 07-02-2019, 06:10 AM Thread Starter
DuraNole's Avatar
I check fuel pressure while turning the truck over. It was 6000+ so I have good pressure. I was able to pull my tune and reload one also. So could my ECM still be bad?
2015.5 LML
Lift pump
DuraNole is offline
post #4 of 6 (permalink) Old 07-02-2019, 06:47 PM
Confused, you said it wouln't crank - and also that you have 6000+ FP while turning it over, so it cranks, but won't start.
RandyHut is offline
post #5 of 6 (permalink) Old 07-02-2019, 08:18 PM Thread Starter
DuraNole's Avatar
Randy, I apologize for the wrong information. The code I don’t believe has anything to do with my issue. Upon further investigation I am only getting around 600kpi rail pressure when trying to crank. So my fuel pressure is not good at all. It will turn over but will not fire. I believe I need around 1800kpi for it to crank? Hoping and praying it’s not my cp4, but not sure what all to check to verify one way or the other. Gonna pull the fpr off the pump tomorrow afternoon to check for debris. But other than that I don’t know what to check. Thanks for responding
2015.5 LML
Lift pump
DuraNole is offline
post #6 of 6 (permalink) Old 07-03-2019, 06:45 AM
JKyle's Avatar
Try loosening the filter on your lift pump, turning the key so the lift pump is on and wait for fuel to spill out. Shut the key off and tighten the filter. May just need to re prime the lift pump.
Jkylew
2012 GMC Denali, Sinister Delete, Fass 150, CP3, Sump, 5" Exhaust, Zone 5" Lift, 35x12.5x20 Nitto Trail Grappler M/T.
JKyle is offline
