Talking someone at GM that has a brain and authority - Page 3 - Chevy and GMC Duramax Diesel Forum
 1Likes
post #21 of 30 (permalink) Old 09-11-2019, 11:27 AM Thread Starter
Originally Posted by DJ Gibson View Post
Anyone know if there is a technical service bulletin out for it? Mine blew yesterday and I am 15k miles over warranty, but still within the 5 years. Sometimes they extend for specific TSB issues, but I'm sure my luck is on the wrong side of this one.
There is no service bulliten or anything out for the cp4 pump good luck getting any help from GM with the repair I didn't so you have a 115k on your truck you can call GMC customer service and they will put your info into a formula to see if you will get any help I was declined because my truck was 764 days out of warranty but it only had 75830 miles on it. Make sure your dealer checks the fuel if it's due to bad fuel your insurance company may help my repair it 10k to fix dealer gave me a 3 year unlimited mileage warranty good luck to you
2012 GMC Sierra 2500HD Diesel 2wd Crew Cab. Stock. 200 mile regen club
nashguy207 is offline
post #22 of 30 (permalink) Old 01-02-2020, 04:55 PM
NYTEAMSTER's Avatar
Any correspondence I've ever had with GM customer support has been useless not very happy with them at all but good luck to you regardless
NYTEAMSTER is offline
post #23 of 30 (permalink) Old 01-02-2020, 05:18 PM
ALLY Cat's Avatar
Originally Posted by Fredn3ck View Post
Yes trucks with lift pumps have grenaded a CP4, see the CP4 failure thread.
I'm under the impression that the "lift pump" that helps prevent CP4 grenading refers to a lift pump with the combined water and fuel filters. As I understand it, the problem is the result of water and/or particle contamination and/or air being pulled into the CP4. I'm pretty sure a lift pump with filters will help make a poorly designed pump last longer, but if I were faced with replacing one, I would opt for a CP3 conversion just for the peace of mind. Another reason to hang on to my antique LLY.....
ALLY Cat is online now
post #24 of 30 (permalink) Old 01-03-2020, 12:33 PM Thread Starter
I agree with they are totally helpless refuse to connect you with anyone that has a say so or any authority I got 0 help and joined a class action law suit
post #25 of 30 (permalink) Old 01-03-2020, 12:35 PM Thread Starter
Dealer checked my fuel no water or any other contaminants found in my fuel I have also seen them fail with a good lift pump
post #26 of 30 (permalink) Old 01-03-2020, 05:09 PM
redwngr's Avatar
The ACDelco/Racor filter used on LML is an excellent' water filter.
CntrlCalDmax likes this.
redwngr is online now
post #27 of 30 (permalink) Old 01-04-2020, 09:33 AM
Originally Posted by nashguy207 View Post
............ I have also seen them fail with a good lift pump
Can you provide a reference?
2012 GMC LML/ALY 4X4 SLE CC 3500HD DRW - STOCK - FuelBox 60 gal Aux tank/Tooll box, Air Lift Bags with SmartAir Leveling System, Exergy Fuel System Saver, Kennedy Single LP - Just fits in the garage.
2007 Mobile Suites 36' TK3 Demco Glide Ride Pin, weighs 17,500# loaded.
2007 GMC LBZ/ALY 4X4 SLT CC 3500 DRW - TransferFlow Tank Tool Box Combo, EFILive DSP5, MBRP, Fred's 1.5 spacers, BD Exhaust Brake.
2004 GMC LLY/ALY 4X4 SLT CC SB, EFIlive, Mike L SCIV, TRADED
2001 Chevy LB7/ALY 4X4 EC SB - SOLD to neighbor
CntrlCalDmax is online now
post #28 of 30 (permalink) Old 01-04-2020, 11:37 AM
you have a p/n?
2002 GMC 2500HD, ECSB, 4WD, LB7
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned by me now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
2016 GMC Denali stock for now
gmc502 is online now
post #29 of 30 (permalink) Old 01-05-2020, 11:53 AM Thread Starter
There is a thread on here cp 4 pump failure you can search for it people there had failures with lift pumps one of the main problems our us diesel does not meet the scar rating that basch spec for the pump
post #30 of 30 (permalink) Old 01-07-2020, 02:52 PM Thread Starter
There is also another thread on here titled cp4 reliability poll it is closed to comments but is 30 pages look in that one
