Best way to verify CP3 installed - Chevy and GMC Duramax Diesel Forum
 59Likes
post #1 of 11 (permalink) Old 08-20-2019, 09:50 AM Thread Starter
I'm wondering what the best way to verify if a CP3 pump was installed on an LML. Is there a tell tale sign visually?
Truck is a 2015 Denali.
Thanks
Dales Super Store likes this.
2007.5 LMM Silverado 2500hd Edge cs2 juice w/attitude tuner, 6" Pro comp, 35s
CraGG is offline
post #2 of 11 (permalink) Old 08-20-2019, 10:20 AM
Blymanb's Avatar
There should be obvious signs like turbo piping changed, intake piping. Also there would have to be a tune installed. Those are the most obvious, other then looking at the unit itself. Can you get a pic of the unit?
What makes you question this?
2011 Chevy Silverado 2500HD CC 4x4 LT Duramax
6.5" BDS - EZ-LYNK - SOTF - S&S Diesel Supersport CP3 - SDP CP3 Conversion Kit - PVC Reroute - 5" Atlas AFE Exhaust Straight Pipe - Air Dog2-4G, 100GPH - HSP Hi-Flo Kit
Blymanb is offline
post #3 of 11 (permalink) Old 08-20-2019, 12:08 PM
I believe the position of the regulator is different, which you should be able to see. I would look at pics of a cp3 and cp4 then verify where the regulator is seated on the truck.
2011 Chevrolet LML
PPEI 60HP tow tune
4" Flo pro w/ muffler
Airdog 4g lift pump
Exergy MPROP
hstechfl is offline
post #4 of 11 (permalink) Old 08-20-2019, 12:29 PM
M.A.M.'s Avatar
If its just a standard cp3 swap, youll have a fuel temp sensor thats not threaded in anywhere but plugged into the harness. In the area of the driver side fuel rail
2017 GMC 3500 DRW/CCLB
--2015 GMC 3500 SRW/CCLB--
M.A.M. is online now
post #5 of 11 (permalink) Old 08-20-2019, 01:15 PM
Blymanb's Avatar
Originally Posted by 6686L View Post
Good idea - that way you wont be posting incorrect info, and well- meaning questioners wont be mislead.
Actually, the info I posted is correct. Hard to mislead anyone with not a lot of info to go on. I simply gave the info that I know from the experiences I've seen and from my install.
Blymanb is offline
post #6 of 11 (permalink) Old 08-20-2019, 02:27 PM
Originally Posted by J83 View Post
Don't mind that guy, hes new, a troll, and super salty. Hes already on multiple peoples ignore list and I'm sure hell burn himself out once people get tired of reacting to his drivel. It does not matter how right you are, how much evidence you produce to defend your opinion or how logical your argument is, he will still only read 20% of what you said, miss quote you and twist your words to get a fight out of you. The rest of us reasonable people appreciate those users who try to offer helpful and polite answers to other users questions.
Well stated.
randallsfield likes this.
gpadoug is offline
post #7 of 11 (permalink) Old 08-20-2019, 08:34 PM
SilverGorillaLML's Avatar
Originally Posted by randallsfield View Post
Jesus...here we go again...the "expert" has returned...
Sent from my VS987 using Tapatalk
Did someone ask for an expert
Originally Posted by Ineedabiggertrailer16 View Post
“Now thats” the “pot” calling the “kettle” “black”
Just because you did your swap your way doesn’t make it the ONLY way. More than one way to skin a hippo
I skin hippos from the dick up. Only way to keep the Cape in good shape.
OP, read what matt said, also theres one return line instead or two. There should be a cap in the passenger side rail that you can visually see from under the filter head.
hookedonpower and J83 like this.
"Flat Back Gorilla" Daily/Tow rig- 04 GMC Sierra LB7 CC Flatbed/Tune/Exhaust
"Empty Pockets" Race/Pulling truck- 2012 CCSB Cummins/Built Engine/
Full Billet 48RE Swap controlled by PCS2000/
B&M Ratchet shifter/Big fuel/Big air/Lowered
SilverGorillaLML is offline
post #8 of 11 (permalink) Old 08-20-2019, 08:47 PM
DirtEmax-USMC's Avatar
Size:  26.7 KBName:  IMG_4591.jpg
Rail cap on passenger side rail courtesy of @SilverGorillaLML
2019 Cummins 3500 Megacab High Output
Patriot Bus
DirtEmax-USMC is online now
post #9 of 11 (permalink) Old 08-20-2019, 08:51 PM
Originally Posted by DirtEmax-USMC View Post
Attachment 1043567Attachment 1043565
Thanks cody.
OP That's an sure way to tell and is fairly easy.
post #10 of 11 (permalink) Old 08-20-2019, 09:05 PM
randallsfield's Avatar
Originally Posted by SilverGorillaLML View Post
Did some ask for an expert
Great info...thank you, sir!
randallsfield is offline
