Opening up the stock exhaust? - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 08-23-2019, 07:41 AM Thread Starter
Ineedabiggertrailer16's Avatar
Couldn’t find anything on this so I’ll ask you guys. Has anybody found a easy way to open up/cut out/expand the factory tailpipe before it goes into the vented section. I’ve got a box of goodies laying in my garage to delete my truck but the local exhaust shop flat out lied to me and they can only bend up to 3” (they SAID they could make a delete pipe) I’ve figured out a fix for that but I’m stuck waiting a few more days for the pipe to show up. I was sniffing around under my truck last night and noticed that while the tail section is 4”, with the tip being 5”, the 4” necks down to 2.75” at the end. Without cutting the bugle off to get at it, how could one go about getting rid of that choke point? I’m going to borrow some pipe expanders from work and try to go in through the tip and flare it out, or try to do some very surgical sawzall work. Might cut the bugle off at the thin strips, cut the cone off and reweld the tip back on. My goal here is to open up the exhaust while leave as much stock stuff on as possible, so if I need to put it back stock in a hurry I can. Thoughts?
And no, I’m not just going to buy an aftermarket exhaust, I’m a tightwad to start with and this last round of hay almost every piece of equipment I own decided to break down in some new and exciting way so my play budget has been diverted to more important things
16í C.C. LT. Tinted, Weather Techs, Boost Tow mirrors, leveled on 35s, Kennedy pump, Ridge Runner, May Truck Parts exhaust
Ineedabiggertrailer16 is offline
post #2 of 11 (permalink) Old 08-31-2019, 01:52 PM
I’m not sure why our exhaust pipe is reduced in diameter right before that vented section. It would require an additional process; which is one thing that makes me wonder if there’s some benefit involved, although I can’t imagine what that would be.
My idea would be to get the largest size hole saw I could that could pass thru the main exhaust pipe. I would make a long drill bit extension, which would give me enough length to reach up the larger tip and reach the main exhaust pipe. In my head, the hole saw would center itself (well enough, at least) on the OD of the main exhaust pipe to allow a slow RPM start with the drill. It would also be easy enough to create bushings for the drill extension to center the assembly in the extension, if needed. I’ve ran the scenario thru my head a few times, and don’t see why it couldn’t work...
Icutmetl is offline
post #3 of 11 (permalink) Old 08-31-2019, 05:46 PM Thread Starter
Iíve been pondering on it and itís just thin exhaust pipe, I think Iím just going to go through the vents with a die grinder and burr (not sure the actual name) and eat the metal away. I was kinda shocked when I measured the outlet at 2.75Ē.
post #4 of 11 (permalink) Old 09-01-2019, 06:40 AM
Exhaust necks now just before the slits to increase velocity and allow room for the cooler outside gases to get sucked in and mixed with the hot regeneration exhaust. I wondered about reaching up in there with a hole saw and just opening it up a little to help it breathe.
2004.5 Silver Birch Metallic GMC K2500HD
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
jlawles2 is offline
post #5 of 11 (permalink) Old 09-01-2019, 09:22 AM
I have some long extensions for my drill,think I'll attach a 3.5" hole saw and have at it.
2002 GMC 2500HD, ECSB, 4WD, LB7
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned by me now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
2016 GMC Denali stock for now
gmc502 is offline
post #6 of 11 (permalink) Old 09-01-2019, 04:11 PM
That was my guess as to why the outlet is the way that it is.
Icutmetl is offline
post #7 of 11 (permalink) Old 09-02-2019, 06:54 PM
should yeild ~1/2 HP on the dyno...
2012 Quicksilver SLT CCSB Sub 200mi regen club, fuel guzzling, dealer queen LEMON...
Amp Powersteps
Insight CTS
305/55/20 Mickey ATZ P3
Bilstein 5100s
Rancho stabilizer
B&W Turnover Ball w/Andersen Ultimate 5er Hitch
Sandman_73 is offline
post #8 of 11 (permalink) Old 09-03-2019, 11:28 AM Thread Starter
People have spent good money on less
post #9 of 11 (permalink) Old 09-03-2019, 08:42 PM
People have spent good money and lost HP. (Just saying)
jlawles2 is offline
post #10 of 11 (permalink) Old 09-04-2019, 06:02 AM
Red face My Plan
The restriction on exhaust really bother me, it seem like really poor engineering from chevy, and reports of melted trailers was a big concern, so I had this idea.
I liked what banks did with exhaust but report of a lot of rust discourged me.
So I order a 4 inch 45 degree Stainless pipe from Summit racing for 45 dollars and painted black with high temp paint. Added a left over tip from another project, and a SS clamp.
I am going to cut off the the "trumpet" section right after the first bend and put this new pipe and tip. I still have to figure out a hanger strap to hold it up but don't think that will be a big problem.
Bullwinkle
Bullwinkle is offline
