P2636 Code - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 09-10-2019, 04:45 PM Thread Starter
P2636 Code
This may be posted somewhere but I haven't found it yet, Anyway, 2016 3500 throwing P2626 code. Recall for fuel line rerouting has been done. On the 3rd transfer pump (replaced last one on 09/05/19). Problem is the truck is only throwing the code when the fuel level gets to 1/4. Doing this both before and after the last pump replacement. Don't know if this makes a difference but when filling up both tanks the front tank holds around 8 gallons and the rear tank will take every bit of 40 gallons. I fill them both as soon as it throws the code. I drive ~500 miles daily pulling 22,000# trailer and getting aggravating having to stop at 450 miles to fill tanks. Before code problem could go appx. 550miles. Thanks in advance for any help.
2016 Chevy 3500HD Duramax
lntransport is offline
post #2 of 3 (permalink) Old 09-10-2019, 05:07 PM
M.A.M.'s Avatar
P2636 Code
Here is something for you to read through, diagnostic help. I havenít had time to read through totally, but just glancing through it looks like there are two different calibrations, is it possible that the wrong one was flashed into your truck by the dealer? Also just glanced at something that said the fuel gauge will default to empty when this DTC sets? Iíll have a little more time later this evening to read through everything.
In order from bottom to top.
2017 GMC 3500 DRW/CCLB
--2015 GMC 3500 SRW/CCLB--
M.A.M. is online now
post #3 of 3 (permalink) Old 09-11-2019, 05:36 PM Thread Starter
Thanks for your help on this. But for now its on the back burner cause I joined the CP4 club this morning.
