This truck is a curse... trans might be toast - Page 6 - Chevy and GMC Duramax Diesel Forum
 43Likes
post #51 of 76 (permalink) Old 09-25-2019, 01:21 PM
Could be they were defective or there may have been some residual from your CP4 that made its way to those injectors. Hopefully replacing those clears up your problem- beats a new motor!
2011 Chevrolet LML
PPEI 60HP tow tune
4" Flo pro w/ muffler
Airdog 4g lift pump
Exergy MPROP
hstechfl is offline
post #52 of 76 (permalink) Old 09-25-2019, 03:33 PM
Your starting to chase your tail.
Injectors die occasionally here and there .
7, all at once?
I'm not buying it, unless you removed every fuel filter on the truck and went to Tijuana for a quick Pemex fill up....
Dales Super Store likes this.
AlisoBob is offline
post #53 of 76 (permalink) Old 09-25-2019, 07:34 PM Thread Starter
mstein86's Avatar
7, all at once?
I'm just telling you what the injector testing company said, They have the $300k bosch test stand and they gave me print outs of each injector. I replaced every line on top of the motor, dropped and flushed the tank, and lines to and from the tank. I also put new filters on too. I think I got some shitty injectors... I'm getting some new ones from LDS, I'm not doing business with that other company. Just so I'm making sense these injectors weren't dead but had little to no output or were stuck open.
AlisoBob likes this.
2012 GMC Sierra 2500HD Denali
Stage 1 short block, ATI damper, Fass 150, CP3, upgraded trans, Up pipe, Down pipe, EZ lynk w/ 5 tunes SOTF, Magnaflow exhaust, PCV re-route, 4 inch Fabtech lift, 35in tires, HD motor mounts
mstein86 is offline
post #54 of 76 (permalink) Old 09-26-2019, 04:21 PM Thread Starter
mstein86's Avatar
Maybe you guys can help me understand this value. 7 out of 8 injectors failed this LL (idle) test. I'm sending the injectors into the company I bought them from so they can test them as well. I have a feeling they will fight me on the warranty. I enclosed the test for injector 1.
mstein86 is offline
post #55 of 76 (permalink) Old 09-29-2019, 05:35 PM Thread Starter
mstein86's Avatar
Cut open the oil filter and drained the oil into a strainer, metal fragments on the filter element and this was in the bottom of the oil filter. Motor is coming out Tuesday... Doubt the injectors were bad, the company I had test them couldn't even call me back to answer a few questions. I'm very disappointed in them...
mstein86 is offline
post #56 of 76 (permalink) Old 10-06-2019, 06:46 PM Thread Starter
mstein86's Avatar
So I finished taking the engine a part this weekend and this is the aftermath...
mstein86 is offline
post #57 of 76 (permalink) Old 10-06-2019, 07:25 PM
PPEI claims another victim.....
eli_harper13 and mstein86 like this.
AlisoBob is offline
post #58 of 76 (permalink) Old 10-07-2019, 04:44 AM
eli_harper13's Avatar
Man thats awful
2011 LML Silverado 2500HD CCSB Z71, Leveled, Bagged, AFE DFS780 Lift Pump, B&W Companion.
eli_harper13 is offline
post #59 of 76 (permalink) Old 10-07-2019, 05:37 AM
407driver's Avatar
Im learning here, I see the push rods all bent, what caused that?
407driver is offline
post #60 of 76 (permalink) Old 10-07-2019, 08:02 AM
The starter spins the crank from the back.
The cam is spun from the gear drive on the front of the crank.
When the crank gets split in two, there is a slight timing issue which bends the shit out of the pushrods.
The fact that the dealer could not identify this engine as a pile of scrap is 5 minutes should make everyone lose all faith in dealerships.
The owner should have every dime he wasted there refunded.....
LMLLover is offline
