This truck is a curse... trans might be toast - Page 7 - Chevy and GMC Duramax Diesel Forum
 43Likes
post #61 of 76 (permalink) Old 10-07-2019, 08:45 AM
So the tune is what ruined the engine ?
the tune made the timing slightly off, then all hell broke loose ?
I'm learning as well ..
1985TS is offline
post #62 of 76 (permalink) Old 10-07-2019, 12:19 PM
No the timing issue happened when the crankshaft broke into 2 pieces
eli_harper13 and mstein86 like this.
2012 GMC Sierra 2500HD Diesel 2wd Crew Cab. Stock. 200 mile regen club
nashguy207 is offline
post #63 of 76 (permalink) Old 10-07-2019, 12:27 PM
I'm not saying the tune was the only cause that made the engine go bye bye but I'm sure it attributed to it depends on what tune and how it was driven several factors can play into this in my opinion IM not an expert and you know what they say about opinions everybody has one lol I do feel sorry for the guy I hate to see this happen to anyone
eli_harper13 likes this.
post #64 of 76 (permalink) Old 10-07-2019, 01:34 PM
eli_harper13's Avatar
This is why I have always ran a stock power level tune. Can't be too careful lol
*Crank breaks tomorrow on stock level tune...
2011 LML Silverado 2500HD CCSB Z71, Leveled, Bagged, AFE DFS780 Lift Pump, B&W Companion.
eli_harper13 is offline
post #65 of 76 (permalink) Old 10-07-2019, 02:40 PM
DIRTEEMAX's Avatar
My worthless 2 cents worth.
I've read the whole post I think the crank just broke .Period. I don't think it was the tunes you would have to be beating the crap out of it for slightly hot tunes to ruin it like that . Also I think your injector shop aint worth 2 squirts of piss . Hence the reason I only use or recommend Lincoln Diesel.
mstein86 likes this.
2002 2500HD 4x4 ccsb
EFI live Idaho Rob
LBZ CP3 and regulator
4'' lift
Ultra Predators
Toyo RT's
WHEN GUNS ARE OUTLAWED I'LL BE THE OUTLAW !!
DIRTEEMAX is offline
post #66 of 76 (permalink) Old 10-08-2019, 04:32 AM
407driver's Avatar
I guess I didn't look close enough at that last pi to see the crank in two pieces.
Yeah that would cause a "slight" timing issue and cause those bent pushrods.........as well as other issues as well.
How could that dealership tell you ALL your cylinders had low compression, half of them were not turning?
J83 and LMLLover like this.
407driver is offline
post #67 of 76 (permalink) Old 10-08-2019, 04:35 PM
reddogg12's Avatar
what journal broke on the crank? I've read with the firing order on the duramax the front of the crankshaft takes a beating.
2012 Silverado 2500 HD LT tuned for reliability, lift pump, 4" exhaust,Stock tires no lift.
1998 VW Beetle TDI
1980 Yamaha MX100 restoration
1971 VW Super Beetle Vert. sold
1971 VW Westy sold
reddogg12 is offline
post #68 of 76 (permalink) Old 10-08-2019, 05:38 PM
J83
J83's Avatar
Originally Posted by mstein86 View Post
So I finished taking the engine a part this weekend and this is the aftermath...
well then that would do it...... Im a little surprised it took the dealer so long to come back with a diagnosis, being the crank is in 2 pieces and rotating the engine to do a compression test might be interesting.
theres stock trucks that have broken cranks, and 2000 HP sled pull trucks that havent. Some times you just get the short straw.
Makes you wonder what exactly the OP paid for vs what he actually got....
J83 is offline
post #69 of 76 (permalink) Old 10-08-2019, 06:22 PM
If the twisting isn't done at the exact right temperature, the metal "tears" at the molecular level, instead of twisting.
This makes a flaw in the structure that may or may not raise it's ugly head during the service life of the part.
AlisoBob is offline
post #70 of 76 (permalink) Old 10-10-2019, 05:57 AM
I think you can get a billet crank for these correct? However, I don't think you need one if your under like 600hp.
SuperBlackTruck is offline
