This truck is a curse... trans might be toast - Page 8 - Chevy and GMC Duramax Diesel Forum
 43Likes
post #71 of 76 (permalink) Old 10-14-2019, 07:29 PM Thread Starter
mstein86's Avatar
Originally Posted by LMLLover View Post
The starter spins the crank from the back.
The cam is spun from the gear drive on the front of the crank.
When the crank gets split in two, there is a slight timing issue which bends the shit out of the pushrods.
The fact that the dealer could not identify this engine as a pile of scrap is 5 minutes should make everyone lose all faith in dealerships.
The owner should have every dime he wasted there refunded.....
The dealership wanted to charge me more money to drop the pan and inspect the inside of the engine. I said no, I was already at a $500 bill from them. I didn't need them to tell me what was broke, I knew it was serious...
2012 GMC Sierra 2500HD Denali
Stage 1 short block, ATI damper, Fass 150, CP3, upgraded trans, Up pipe, Down pipe, EZ lynk w/ 5 tunes SOTF, Magnaflow exhaust, PCV re-route, 4 inch Fabtech lift, 35in tires, HD motor mounts
mstein86 is offline
post #72 of 76 (permalink) Old 10-15-2019, 01:02 PM
You got ripped off at most they should of only charged you an hour diagnostic fee
2012 GMC Sierra 2500HD Diesel 2wd Crew Cab. Stock. 200 mile regen club
nashguy207 is offline
post #73 of 76 (permalink) Old 10-25-2019, 06:28 PM
Any updates on the engine install
Sent from my SM-G955U using Tapatalk
SkeetSkeet is offline
post #74 of 76 (permalink) Old 10-26-2019, 09:11 PM Thread Starter
mstein86's Avatar
Got the front of the frame sealed with POR-15, I didn't want gloss black but it was all they had. I'm painting the frame flat chassis black tomorrow. I should get the short block in about 5 days, I rebuilt the turbo, getting the hot side a part was difficult and also seating the hot side was a pain, very tight fit. Transmission and heads are done, I pick those up next week. Still waiting on the driveshafts...
Noble_dmax and M.A.M. like this.
mstein86 is offline
post #75 of 76 (permalink) Old 10-31-2019, 06:52 PM Thread Starter
mstein86's Avatar
I'm picking up the transmission and heads tomorrow. I'm going with the Mahle 54597 and 54598 head gaskets. Any pro's or con's to this head gasket?
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
mstein86 is offline
post #76 of 76 (permalink) Old 11-01-2019, 01:20 PM
I would talk with mam on here he is pretty knowledgeable about these engines he has 2 threads on here
mstein86 likes this.
