Moderate LML engine rebuild... - Page 5 - Chevy and GMC Duramax Diesel Forum
 24Likes
post #41 of 64 (permalink) Old 10-18-2019, 07:03 PM
denarli6.6's Avatar
I think if it ever comes time to get a short block built I'm gonna look into swamps diesel. Very reasonable prices from what I've seen and their warranty is pretty jam up by the sound of it.
https://swampsmotorsports.com/produc...-block-engine/
2016 LML Denali 2500
Mcgaughy's 2" drop shackle
Bilstein 5100
22x10 American Force Flux black w machined or Toyos on OEM wheels. Depends on the day of the week
Wehrli S300 kit w/ 66mm SXE
Profab Manifold & Up-pipes
Stock Trans For Now
Stock Sticks For Now
Air Dog 165 4G
denarli6.6 is online now
post #42 of 64 (permalink) Old 10-18-2019, 08:53 PM
Noble_dmax's Avatar
[QUOTE=J83;12218517]
The Duramax engine is an exceptional engine, but it is also far from perfect. There are plenty of issues with it from the beginning of the series, most have been corrected by this point but the crank issue as far as i am aware has never been addressed by GM. It is not a huge issue, as failures are rare, but there is still a clear history of failures going back to the 01 trucks..
[QUOTE=SilverGorillaLML;12218567]Agreed!!
From 01 to 16 these trucks break cranks on, stock or 2000hp, babied or abused, low mileage or high. Doesnt matter. Hit or miss. Unfortunately the af cams have proven not to be the fix all eveyone thought they'd be. Plenty of guys have broken cranks with those also.
Comprendo? Now, go away.
2018 GMC l5p ccsb stone blue metallic. Mcgaughy's 2" drop shackles. Truxedo tonneau cover. 20% tint. B&W turnover ball hitch. N Fab running boards, Duraflaps, Rhino lined bed
Traded:05 lly ccsb 205k miles, built trans and supporting mods
Traded:09 LMM CCLB Bone stock, fully loaded. 86xxx miles.
Noble_dmax is online now
post #43 of 64 (permalink) Old 11-15-2019, 04:07 PM Thread Starter
mstein86's Avatar
Got my engine but they didn't install the crankshaft gear, the one that drives the cam. They are shipping me one out ASAP, what the best way to install this? Should I bake the gear to 400 degrees for 30min so it slides on easier? Any help or suggestions would be appreciated.
poosniffer likes this.
2012 GMC Sierra 2500HD Denali
Stage 1 short block, ATI damper, Fass 150, CP3, upgraded trans, Up pipe, Down pipe, EZ lynk w/ 5 tunes SOTF, Magnaflow exhaust, PCV re-route, 4 inch Fabtech lift, 35in tires, HD motor mounts
mstein86 is offline
post #44 of 64 (permalink) Old 11-15-2019, 04:20 PM
denarli6.6's Avatar
Is this the short block from DMAX store???
Bilstein 5100
Stock Trans For Now
Air Dog 165 4G
post #45 of 64 (permalink) Old 11-15-2019, 04:49 PM Thread Starter
mstein86's Avatar
yes it is
mstein86 is offline
post #46 of 64 (permalink) Old 11-15-2019, 05:33 PM
denarli6.6's Avatar
yes it is
What did you end up going with as far as internals go?
Bilstein 5100
Stock Trans For Now
Air Dog 165 4G
post #47 of 64 (permalink) Old 11-15-2019, 05:35 PM
M.A.M.'s Avatar
Baking the timing gear will work fine. I installed mine on the crank before it was in the block, and put the crank in the freezer for a while as well. Should slide right on for you.
mstein86 likes this.
2017 GMC 3500 DRW/CCLB
--2015 GMC 3500 SRW/CCLB--
M.A.M. is online now
post #48 of 64 (permalink) Old 11-15-2019, 05:48 PM Thread Starter
mstein86's Avatar
New Stage 1 block
Callies durastar AFO camshaft
DMAX performance crankshaft
DMAX performance connecting rods
MAHLE motorsports performance cast pistons
ARP main stud kit
mstein86 is offline
post #49 of 64 (permalink) Old 11-15-2019, 05:55 PM
SilverGorillaLML's Avatar
Yes you can bake it on.
NIC R
"Flat Back Gorilla" Daily/Tow rig- 04 GMC Sierra LB7 CC Flatbed/Tune/Exhaust
"Empty Pockets" Race/Pulling truck- 2012 CCSB Cummins/Built Engine/48RE Swap/PCS2000/
B&M Ratchet shifter/Big fuel/Big air/Lowered
post #50 of 64 (permalink) Old 11-15-2019, 06:06 PM Thread Starter
mstein86's Avatar
M.A.M. so I'm following ALLDATAdiy.com for the rebuild procedure and I'm worried about installing the cam wrong. The website just says to line up the timing marks on the crankshaft gear and camshaft gear. Can it be that easy?
mstein86 is offline
