Moderate LML engine rebuild... - Page 6 - Chevy and GMC Duramax Diesel Forum
 24Likes
post #51 of 64 (permalink) Old 11-15-2019, 06:46 PM
M.A.M.'s Avatar
Originally Posted by mstein86 View Post
M.A.M. so I'm following ALLDATAdiy.com for the rebuild procedure and I'm worried about installing the cam wrong. The website just says to line up the timing marks on the crankshaft gear and camshaft gear. Can it be that easy?
Yeah, itís that easy. The cam and crank both have keys or pins so you canít install the gear wrong onto them. From there you just line up the timing marks. Canít go wrong.
mstein86 likes this.
2017 GMC 3500 DRW/CCLB
--2015 GMC 3500 SRW/CCLB--
M.A.M. is online now
post #52 of 64 (permalink) Old 12-15-2019, 08:44 AM Thread Starter
mstein86's Avatar
OK got the engine in and everything buttoned up, turns over but wont fire. I have a fass 150 so I know the filter head in the engine bay has fuel, the plunger is hard. I cracked the bleeder screw to make sure there is no air. I tried putting compressed air to the fuel return line, I guess it needs 80psi to help the injectors work. I have a small fuel leak in the valley, not sure if its coming from the CP3 or a fuel line. I noticed fuel dripping down the back of the engine. I'll look at that today. I also reloaded the tune as well. Any suggestions?
2012 GMC Sierra 2500HD Denali
Stage 1 short block, ATI damper, Fass 150, CP3, upgraded trans, Up pipe, Down pipe, EZ lynk w/ 5 tunes SOTF, Magnaflow exhaust, PCV re-route, 4 inch Fabtech lift, 35in tires, HD motor mounts
mstein86 is offline
post #53 of 64 (permalink) Old 12-15-2019, 10:27 AM
kiwi lml's Avatar
If you have a slight fuel leak in between cp3 and injectors it wont build enough pressure to let it fire up.
I had that happen to me one time, was such a small leak that about over looked it on the fuel rail.
Sent from my SM-G977U using Tapatalk
2016 lml chevy ccsb. Last december installed a HSP compound turbo kit with a stainless diesel 5 blade S475 over stock. And a exergy 10mm cp3 conversion kit but still stock injectors and transmission. 5" flo-pro exhaust with no muffler and tuning is done with EZ Lynk by PPEI.
kiwi lml is offline
post #54 of 64 (permalink) Old 12-15-2019, 11:02 AM Thread Starter
mstein86's Avatar
Thanks, I'll definitely fix the leak first
mstein86 is offline
post #55 of 64 (permalink) Old 12-15-2019, 11:22 AM
M.A.M.'s Avatar
Are you certain all the grounds are connected. I missed one on the front of the engine that was for the ecm, and it cranked but didnít fire. It would be good to hook up a scanner and see if itís building rail pressure or not.
How long have cranked it over already.? It takes a good while to work the air out of a dry system.
post #56 of 64 (permalink) Old 12-15-2019, 11:25 AM Thread Starter
mstein86's Avatar
I'm pretty sure all the ground wires are hooked up. does the ez-lynk have a rail pressure option?
mstein86 is offline
post #57 of 64 (permalink) Old 12-15-2019, 11:43 AM
M.A.M.'s Avatar
Yes it should have. Watch what actual rail pressure is. Should be somewhere between 4-6k, IIRC.
post #58 of 64 (permalink) Old 12-15-2019, 12:12 PM Thread Starter
mstein86's Avatar
What is the name of the one I want to watch, lots of ones named injection pressure etc...
mstein86 is offline
post #59 of 64 (permalink) Old 12-15-2019, 12:15 PM Thread Starter
mstein86's Avatar
Injection pressure (A) is 0.0
Injection pressure (D) is 6.1
mstein86 is offline
post #60 of 64 (permalink) Old 12-15-2019, 06:53 PM
M.A.M.'s Avatar
Yeah, youíre not building any rail pressure. How long have you cranked it over already trying to start it? Can you take off the supply right at the cp3 just to make sure you have fuel there?
You can try pinching the return fuel line where it goes down below the cab, but need the second person to immediately release it it does start.
