Moderate LML engine rebuild... - Page 7 - Chevy and GMC Duramax Diesel Forum
 24Likes
post #61 of 64 (permalink) Old 12-16-2019, 06:10 AM Thread Starter
mstein86's Avatar
Originally Posted by M.A.M. View Post
Yeah, you’re not building any rail pressure. How long have you cranked it over already trying to start it? Can you take off the supply right at the cp3 just to make sure you have fuel there?
You can try pinching the return fuel line where it goes down below the cab, but need the second person to immediately release it it does start.
I will try pinching the fuel return next after I fix the coolant leaks. I found one being the radiator. I think the other is the thermostat housing where it connects to the block. I had to remove it one I had everything tight, I forgot to run some wires behind it. I have a felpro thermostat gasket set, they are the softer gasket material not the metal ones GM uses, I'll just add a little RTV and I should be good to go.
2012 GMC Sierra 2500HD Denali
Stage 1 short block, ATI damper, Fass 150, CP3, upgraded trans, Up pipe, Down pipe, EZ lynk w/ 5 tunes SOTF, Magnaflow exhaust, PCV re-route, 4 inch Fabtech lift, 35in tires, HD motor mounts
mstein86 is offline
post #62 of 64 (permalink) Old 12-23-2019, 04:41 PM Thread Starter
mstein86's Avatar
Got the beast done... started on the 3rd crank. Thanks for everyone's help, it was really appreciated. Found the fuel leak, it was the hard line from pass. rail to the CP3. It was loose on the CP3. Coolant leak was the radiator and the thermostat housing where it bolts to the block. Replaced all the gaskets and radiator, well the new radiator leaks so I'm trying to get them to replace it. It was an aftermarket from a reputable diesel company, should have paid the extra money and gone OEM...
CDmax16 likes this.
mstein86 is offline
post #63 of 64 (permalink) Old 12-24-2019, 02:07 PM
Glad to here you got it running. Sorry to hear about the new radiator leaking if they are a repitul company they should stand behind it. Let us know what happens on the radiator and if they don't take care of it tell us the name of the company so we can avoid them in the future
2012 GMC Sierra 2500HD Diesel 2wd Crew Cab. Stock. 200 mile regen club
nashguy207 is offline
post #64 of 64 (permalink) Old 12-29-2019, 02:44 AM
poosniffer's Avatar
Great to hear that you got it running!
2018 Toyota Tundra Platinum Crewmax
SOLD:2008 LMM Silverado 2500 LTZ ECSB 4X4.
Aftermarket DSP5 calibration by Danville Performance, Blocked and re-routed, Nicktane with Baldwin BF7587, PPE lift pump with Baldwin BF1212 water separator, 285/75/17 Dura Grapplers on H2s, CTS Insight with pyro.HIDs in fogs and high beams.
Proud Member U/A Local 693 Plumbers/Pipefitters.
poosniffer is offline
