Lift pump question - Page 3 - Chevy and GMC Duramax Diesel Forum
 10Likes
post #21 of 24 (permalink) Old 10-02-2019, 04:40 AM
LHN...We ARE the Joneses
based on the design of the actual pump itself if it would flow fuel if the motor seized.
ding...ding...ding
I thought that also.
Less likely with a magnetically coupled design.
Hook'em_Horns! is online now
post #22 of 24 (permalink) Old 10-02-2019, 05:14 AM
407driver's Avatar
Meaning the motor and impeller are coupled via an electro magnet that is powered when the pump is on?
If so, what mechanism would disconnect that bond if the motor stopped and the circuit was still activated? Or is the motor design such that it virtually never seizes?
407driver is online now
post #23 of 24 (permalink) Old 10-02-2019, 06:41 AM
Usual failure is a shaft bearing, which it doesn't have.
post #24 of 24 (permalink) Old 10-03-2019, 06:42 PM
mulefan3220's Avatar
I’ve got 40k miles and about 3 years on my Kennedy twins. No issues. According to my Insight they keep pressure between 7 and 8psi just before the stock filter head. Might drop to 6psi at 3k rpm pulling my toy hauler in the mountains. The old fuel cooler bracket in front of the tank on my ‘14 makes a nice spot for mounting the pumps.
2014 GMC 3500 SLT CCLB Z71 SRW
Mostly stock except for all the $$ I spent on bumpers, tires, wheels, leveling kit, air bags, lift pumps, air intake, Powerstops, and the Insight.
mulefan3220 is offline
