4" or 5" exhaust - Chevy and GMC Duramax Diesel Forum
 7Likes
post #1 of 14 (permalink) Old 10-27-2019, 10:12 PM Thread Starter
4" or 5" exhaust
I am looking for a quiet exhaust. Videos I have watched are making me think the 5" with muffler is the most quiet option. (this is will be a delete btw) Anyone have experience with Aero mufflers? Would this give me a much more quiet exhaust?
Thanks!
Trevor Campbell is offline
post #2 of 14 (permalink) Old 10-28-2019, 12:36 AM
mizterwizard's Avatar
Generally speaking the larger the diameter the louder it is because people tend to use straight through mufflers with aftermarket pipes. If you want quiet you want to stick with stock.
If you just have to throw money at your exhaust then look for a muffler that has baffles inside, not straight through.
Dales Super Store likes this.
mizterwizard is offline
post #3 of 14 (permalink) Old 10-28-2019, 02:37 PM
denarli6.6's Avatar
4 is quieter than 5. I'd buy a straight pipe kit and install a 30" resonator instead of a kit with a muffler. FTE knocks out the drone and muffles.
2016 LML Denali 2500
Reverse level with Mcgaughy's 2" drop shackle
Bilstein 5100 all-around
22x10 American Force Flux black w machined
Wehrli S300 kit w/ 66mm SXE
Profab Manifold & Up-pipes
Stock Trans For Now
Stock Sticks For Now
Air Dog 165 4G
Off-road Only
denarli6.6 is online now
post #4 of 14 (permalink) Old 10-29-2019, 11:38 AM
J83
J83's Avatar
As one of those people who owns a straight through muffler i can can confirm for you its not quiet.
J83 is online now
post #5 of 14 (permalink) Old 10-29-2019, 01:06 PM
Location: we live in a high mountain valley in the hi country of northern arizona
I deny everything - just "what I have heard"....just "hypothetically speaking" if I did a "full delete", so that my DPF and CAT are now safely stored.....I would chose 4" for the reasons stated in the above posts.
The exhaust kit that came with my "hypothetical" delete kit did have a muffler - standard "straight thru". Was fairly quiet, but not quiet enough. Had a ( again, hypothetical speaking.....!) 2nd "straight thru" muffler installed - much quieter - now almost as quiet as "stock". Yes, you could get it as quiet as stock, but then you'd have some back-pressure. I do not know if a modern big 4" truck muffler with baffles would add significantly to "back pressure" - guess whether it is significant would depend on what you use your truck for.
mizterwizard likes this.
2013 3500 long bed crew cab. Purchased at approx. 80,000; now have 91,000, convert to CP3. DPF "triggerd" a limp mode, so was cut out of the vehicle & cleaned by a DPF cleaning co., on re-installation, everything back to normal. Would never ever think of something as nasty and as anti bunny wabbet as a full-delete...after all..dosnt everyone like the fun & excitement of being stuck by the side of a Interstate in the ran while towing when one's truck's computer decides to go into "limp mode"...?.
6686L is online now
post #6 of 14 (permalink) Old 10-29-2019, 08:03 PM
Ultimately you are unlikely to gain enough power from a large exhaust to make any difference other than maybe nosing out your buddy in his totally stock truck. As far as economy goes, it would never pay for itself in a lifetime of use.
Large exhausts work well on highly modified trucks making north of double the stock power and they give you something to bench race about but otherwise they have little value.
Here's some other ideas of thing you could do to your exhaust to make your truck stand out:
post #7 of 14 (permalink) Old 10-29-2019, 11:02 PM
D_R_C's Avatar
Quiet exhaust with a 4” or 5” there’s no such animal.
Leave the stock cat go straight back open exhaust from the cat back add a 30” FTE resonator/muffler.
Less stink with the cat and less drone with the FTE, aftermarket cats like the Magnaflow does nothing to tone down the stinky exhaust.
4” or 5” back, at this point it won’t matter, 5” might have a little deeper tone.
Mine did with 5” filterless back exhaust with 6” vented tip, compared to 4” back with stock bugle looking tip.
Dan
EFILive TCM Duramax Tuner
DHD PCV Re-Route
AirDog 4G100
D_R_C is offline
post #8 of 14 (permalink) Old 10-31-2019, 05:49 AM
eli_harper13's Avatar
For the price, this 30" muffler is great quality and really quiets down a 4" straight pipe. It is a flow through design, but I can confirm that it took away all drone while cruising. I was very surprised out how much this quieted the truck down. I have never heard this muffler while towing though. For the price of $50, you can't beat it. I am pretty sure it is the exact same muffler MBRP sells for $150.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2011 LML Silverado 2500HD CCSB Z71, Leveled, Bagged, AFE DFS780 Lift Pump, B&W Companion.
eli_harper13 is offline
post #9 of 14 (permalink) Old 10-31-2019, 01:12 PM
J83
J83's Avatar
That sure looks like what came with my MBRP kit.
J83 is online now
post #10 of 14 (permalink) Old 10-31-2019, 02:01 PM
Seriously? lol. I was gonna order the MBRP muffler that was $150 but saw one review for it that stated they received an unmarked muffler that looked like the $50 one. So I took a gamble on it and I am glad I did. Truck is almost as quite as stock inside the cab. Not much louder than stock outside. $50 is much better than $150
