15 LML Lift Pump Fuse Tap Location - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 11-19-2019, 06:44 AM Thread Starter
6.5 Diesel's Avatar
I have a 15 LML that i have had deleted for about 3.5 years. When i did the delete, i installed an AirDog 4g lift pump, but i could never get the fuse tap into a fuse slot under the hood that was key on power only. I searched and searched the fuse box but none of the fuses labeled (ign) were accessible to fit the fuse tap into them. A relay was always in the way. Forward to this year, i helped a buddy delete his 14 and he had all kinds of fuses accessible that were ignition only. It seems as if GM redesigned the layout of the fuse boxes from 14 to 15 and later.
Long story short, what did guys with 15 and newer LMLs do to tap into an ignition only source. Maybe i missed a fuse but i was just wondering if someone could point me in the right direction. As I currently have it installed, the pump runs any time the door is opened but shuts off after like 20 seconds when the key is not on.
Thanks
2015 Chevy LML 2500HD LTZ CC/LB
14" Duraflap Mudflaps
ICI SS Running Boards
Bushwacker OE Fender Flares
Northland Aluminum Front Bumper
EDGE CTS2/EGT Probe
MBRP Downpipe /5" Flo Pro Exhaust
PPEI ECM/TCM Tunes
Airdog 4g 165 Lift Pump
Deviant EGR Plates/Merchant Auto PCV Reroute
295/55R20 Toyo MT's on Stock Rims/Height
6.5 Diesel is offline
post #2 of 4 (permalink) Old 11-19-2019, 08:29 AM
I powered my lift pump on my 2008 truck from a pin in the MBEC (near the brake pedal under the dash) that is powered with key on. The pin is fused (15 amps, I think). You could get a wiring diagram for your year on GMUPFITTER.COM in the body builder section, look for MBEC and see what's available.
Ron Nielson
Ron Nielson is offline
post #3 of 4 (permalink) Old 11-19-2019, 08:35 AM
xerobytez's Avatar
Take a look at the link below, these are install instructions for a FASS pump for a 15-16 LML but it shows you which fuses they are tapping to get ignition power.
https://fassride.com/wp-content/uplo...all-Manual.pdf
2015.5 GMC Sierra 2500HD Denali LML Duramax
2007.5 Silverado 2500HD LTZ CCSB LMM Duramax - Triple Black (SOLD)
2008 Silverado 1500 LT 5.3 CCSB AFM Deleted - Olympic White (SOLD)
xerobytez is offline
post #4 of 4 (permalink) Old 11-19-2019, 09:13 AM Thread Starter
6.5 Diesel's Avatar
I remember looking at that location but i was nervous about that sharp bend in the wire right after the fuse tap.....looks like FASS isnt too worried, so i might just do that then.
Thanks for the reply
EDGE CTS2/EGT Probe
PPEI ECM/TCM Tunes
