2016 20'' Rim Specs - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 19 (permalink) Old 12-06-2019, 01:37 PM Thread Starter
MJA
MJA's Avatar
2016 20'' Rim Specs
Could someone tell me the stock rim specs for a 2016 20'' rim. Some have said the offset is +44 others have said +31 with 5.97 backset? Im looking at a different rim that is 20x9 with +18 and 5.71 backset. I will putting on BFG KM3's 35x12.50R20 and I'm looking into how much clearance I will have. I will be adding a lift, I just dont know how much I need or if I can get away with nice leveling kit with UCA's with a diff drop.
Thanks
2106 2500HD Butte Red, 285/65/r20 BFG KO2
MJA is offline
post #2 of 19 (permalink) Old 12-06-2019, 02:36 PM
M.A.M.'s Avatar
+44
2017 GMC 3500 DRW/CCLB
--2015 GMC 3500 SRW/CCLB--
M.A.M. is online now
post #3 of 19 (permalink) Old 12-06-2019, 04:24 PM
denarli6.6's Avatar
You can get away with a leveling kit on that set up or a 4-6" lift turned all the way down. personally i would do a 4-6" and turn it all the way down with no blocks in the rear to keep your ride quality.
MJA likes this.
2016 LML Denali 2500
Mcgaughy's 2" drop shackle
Bilstein 5100
22x10 American Force Flux black w machined or Toyos on OEM wheels. Depends on the day of the week
Wehrli S300 kit w/ 66mm SXE
Profab Manifold & Up-pipes
Stock Trans For Now
Stock Sticks For Now
Air Dog 165 4G
denarli6.6 is online now
post #4 of 19 (permalink) Old 12-06-2019, 06:56 PM
DRAElectrician's Avatar
I have a 2016 also and I was wondering if 35s will clear with Factory 20s. You can read some say yes some say no some say yes no cranking let me know how your outcome is . I had 2015 with 7.5 in lift and 35s. It road like silk I will admit but it was hard on the front end when I first had a level before the lift. If mine will hold 35s factory and no rub I would be tickled.
2016 GMC CC, Fass 165 , DT 520 tunes Tranny an Motor with DP5 switch, CTS2, DPF back 5 inch for looks. Next step Trans Build and Stealth G2 Turbo.
DRAElectrician is offline
post #5 of 19 (permalink) Old 12-06-2019, 08:58 PM
Your best bet is probably a 275/65r20 “34.1” on stock suspension.
LML6600DMAX is offline
post #6 of 19 (permalink) Old 12-07-2019, 08:20 AM
sorry to say,,they rub,,just a touch on the frame,,not on the stock sway bay,,my hellwig bar just gets touched.my tires BFG KO2's 35x12.50x20.they make the truck look good.my bars are cranked on,from ground to the little crease in the fender well molding,I'm at 43"
friends truck on the left,he plows too
I'll see if I can get pics of the rubbing.
2002 GMC 2500HD, ECSB, 4WD, LB7
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned by me now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
2016 GMC Denali stock for now
gmc502 is offline
post #7 of 19 (permalink) Old 12-07-2019, 07:15 PM
Thanks Man yeah I already have it cranked a inch and haven’t seen any change but I have coppers maxx and they are chopped bad. Chevy says alignment is in spec but it pulls hard right. At 80k I think the front end is ready for parts. I run 50# air all around. I was thinking 35s but I know there hell on front end parts. Plus I don’t have a bumpsteer shock. I may upgrade the front end before I go with 35s! I’m ready for tires soon oh.
post #8 of 19 (permalink) Old 12-08-2019, 08:22 AM
now my truck had been aligned before the switch.It ran nice and straight,even w/ a very slight back and forth movement on the front end steering parts.
after switch,throw truck on the rack,,believe it or not,all was good but an ever so slight toe out,some thing like .02 °.adjusted and it runs perfect on the highway,
running 60psi in all the tires.
gmc502 is offline
post #9 of 19 (permalink) Old 12-08-2019, 04:57 PM
So GMC502 you have 35s ? That looks good and I think you have me sold it works if that’s 35s. It looks so much better than those little tires. I had my doubts on the looks vs function, but my baby is just a horsepower and weekend pounder. It’s never pulled are been worked just drove. I have other trucks for that but I think I will go this route. I about have it how I want it with my cp3 conversion and built Trans and 200hp tune. This has been a wonderful lml and has performed flawlessly from day one compliant and non compliant. I think it’s just time for a front end rebuild unless my cooper Maxxs are just poorly made. They are loud and chopped and have been rotated every 5k and only have 25k on them.
post #10 of 19 (permalink) Old 12-08-2019, 05:18 PM
my tires are 35x12.50x20's
gmc502 is offline
