Which lift pump/fuel filter system - Chevy and GMC Duramax Diesel Forum
 3Likes
post #1 of 13 (permalink) Old 01-19-2020, 01:23 PM Thread Starter
I've had my 2014 LML since it was new. Currently sitting at 75K miles. Wanting to start making it more reliable. I'm wanting to start with a lift pump and filter system. Anybody have any recommendations between FASS, Airdog, or dieselfuelfilterkits.com? Thanks for any info.
JeepHauler37 is offline
post #2 of 13 (permalink) Old 01-19-2020, 01:31 PM
LHN...We ARE the Joneses
Another DFFK ad post from a new join.
Might want to use the 'SEARCH' function, as it's a more than common topic.
Hook'em_Horns! is online now
post #3 of 13 (permalink) Old 01-19-2020, 04:58 PM Thread Starter
Yep, new guy, you caught me. Wasn't trying to advertise for anybody. Just had a question. Thanks
post #4 of 13 (permalink) Old 01-19-2020, 05:11 PM
Sorry....I just see patterns and this is the 2nd day in a row, same time of day, to see some inquiry about an obscure option.
Serious about the search, years of data available here.
The Silver Fox likes this.
post #5 of 13 (permalink) Old 01-19-2020, 05:34 PM
Armus's Avatar
Common on all popular boards: https://en.wikipedia.org/wiki/Shill
DPF/SCR technology summarized in three words: It doesn't work.
Armus is offline
post #6 of 13 (permalink) Old 01-19-2020, 05:36 PM Thread Starter
I'm finding some good info. Also read the "New Here" thread. Sounds like that dieselfuelfilterkits. com kit isn't very popular around here. Was leaning towards airdog but after seeing the wehrli mount for the fass to keep it inside the framerails that sounds nice too. The fass being right in front of the rear tire seems like problems waiting to happen(I live on gravel roads). I also like for anything that makes the truck look modded to be completely out of sight.
post #7 of 13 (permalink) Old 01-19-2020, 06:23 PM
Airdog or Fuelab
silvergmc is offline
post #8 of 13 (permalink) Old 01-19-2020, 10:22 PM
D_R_C's Avatar
The only brand Iíve had is AirDog 4G100 which is good for up to 600 hp from what most say.
AD with filters, IMO has a good mount set-up much better than one of the other ones mentioned.
Pretty much in between the front and rear tires, mounts inside and above the bottom of the frame, easy connection no hose cutting and a lifetime motor warranty.
If you go with the larger LP like the 165 on FASS or AD, you might be in for a few issues including fuel psi being a little higher 12-14 which is higher than whatís recommended for the Duramax which is 8-10.
Dan
EFILive TCM Duramax Tuner
D_R_C is offline
post #9 of 13 (permalink) Old 01-19-2020, 10:48 PM
https://www.duramaxforum.com/forum/1...stall-lml.html
With the Kennedy there are no sumps, draw straws, return lines, noise, foam, fluctuating fuel pressures, idle surging, or any of that other crap.
You put it on, and forget about it. It just plain.....works.
ShopSpecialties and SheeB like this.
AlisoBob is online now
post #10 of 13 (permalink) Old 01-20-2020, 12:16 AM
Riley 1820's Avatar
Agree with above. Have the dual setup, also if they should fail injection pump can pull thru them.
2012 3500hd srw 4 wd Jamco exhaust Kennedy dual lift pump Trifca bed cover B& W gooseneck hitch Western Diesel fuel filter relocation bracket
Riley 1820 is offline
