What's The Best Cold Air Intake - Page 2 - Chevy and GMC Duramax Diesel Forum
 1Likes
post #11 of 25 (permalink) Old 07-11-2015, 07:49 AM
830king's Avatar
I have a S&B cai with dry filter on my lly, let's just it's say major improvement over stock......
My name is Dan, I drive a 2005 2500hd ccsb lly 4x4, victory red, Efi live Robs trans safe tunes, Edge cts w/pyro, Silverline 5" exhaust, Magnaflow downpipe, LML ds manifold, Arp head studs, S&b turbo inlet, S&b cai dry filter, Ppe shim kit, drilled fuel rails, B&w turnover gooseneck, Ma welded waterpump, Profab egr delete, Fass titanium 150, Beans fuel sump, Ma pump rub plate, 285/75-16 duratrac on stock rims, Kryptonite tie rod & centerlink, Kryptonite sway bar end links, kryptonite lower ball joints Rare parts extreme duty pitman and idler arms, Dhd steering brace, Alligator 5/8" trans lines.
830king is offline
post #12 of 25 (permalink) Old 07-11-2015, 09:04 AM
Armus's Avatar
Yes, we've heard that 40 hp claim before. Seems optimistic to me, unless the stock filter it replaced was completely plugged or the engine was substantially modified.
DPF/SCR technology summarized in three words: It doesn't work.
Armus is offline
post #13 of 25 (permalink) Old 07-11-2015, 09:13 AM
SilverGorillaLML's Avatar
I'm getting ready to order a afe drop in or just a whole s&b. With how dirty my filter is I could see a 40hp gain haha. Not doubting someone, somewhere, on some dyno, didn't pick up 40, but that is a lot from an intake.
NIC R
"Flat Back Gorilla" Daily/Tow rig- 04 GMC Sierra LB7 CC Flatbed/Tune/Exhaust
"Empty Pockets" Race/Pulling truck- 2012 CCSB Cummins/Built Engine/48RE Swap/PCS2000/
B&M Ratchet shifter/Big fuel/Big air/Lowered
post #14 of 25 (permalink) Old 07-11-2015, 09:36 AM
DaJokr's Avatar
They allow more air to pass through, so I can understand a "marginal" increase. But then your allowing more dirt in too. I guess what we should be saying is if you want the best filtration and average performance, stay stock. If you want a little more air and are willing to lose filtration, go aftermarket.
Beastly Build
LBZ Drag Racing
2006 GMC LBZ 4x4 CC/SB
1/4 Mile [email protected]
1.793 60'
DIED 09/19/17 11:02AM
REVIVED 12/21/17 3:57PM
DaJokr is offline
post #15 of 25 (permalink) Old 07-11-2015, 10:02 AM
830king's Avatar
I thought the Donaldson Powercore filtered better then stock with more airflow too, can anyone verify? I'm thinking a Powercore is gonna be my next filter, a 61502 should fit right on my S&B cai.
830king is offline
post #16 of 25 (permalink) Old 07-11-2015, 12:08 PM
SoCalMike is offline
post #17 of 25 (permalink) Old 07-12-2015, 01:48 PM
On the 15 lml I do not think it's worth it, I plan on dropping an afe or s&b dry filter in the factory box.
Streetcar is offline
post #18 of 25 (permalink) Old 07-12-2015, 11:44 PM
Jacqson's Avatar
Filtration between the Powercore and OEM is pretty close 99.97% compared to 99.90% but the Donaldson flows around 800CFM. I'm not sure what the OEM filter flows at but AFAIK it doesn't flow anywhere near 800CFM. I got the S&B intake with the Donaldson Powercore filter on my rig.
2011 Silverado 3500HD SRW LML CCSB LTZ. Line-X over the Rail, Rockers and Side Steps, S&B Intake w/Donaldson Powercore G2 Filter & Scoop, Kennedy Twins/W Filter, Edge Insight CTS, Crown Performance SS Brake Lines, PPE Rear Diff Cover, Bushwacker Fender Flares, Cognito Leveling Kit with UCA's & Steering Braces, Rare Parts Tie Rods, Bilstein 5100's, KC Light Bar, Rigid Dually D2's, LT295/70R/18 Terra Grapplers, Allison Deep Trans Pan, Transynd, Suncoast Filter Lock, Retro Solutions 5000K HID's in my Fog Lamps, Snugtop Canopy plus a few other Goodies.
Jacqson is offline
post #19 of 25 (permalink) Old 07-13-2015, 09:18 AM
I like the dry filters because they are easy to clean an will still give you good protection in the factory air box .
post #20 of 25 (permalink) Old 01-27-2020, 08:15 AM
deez112's Avatar
Anyone have updates on they're current aftermarket intake, for LML? Im about to get the $300 S&B intake, for a good price! But, needing to know if its even worth the bother?
16" LML LT BLACK HAMMER
5"Jamo
ANARCHY EFI LIVE
FASS165GPH/FASS HEATER
G&R SUMP
Block-off plates
INSIGHT EDGE CTS2
SPYDER AUTO TAILS
CougarMotor LEDs
Morimoto Fogs
deez112 is offline
