What's The Best Cold Air Intake - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 25 (permalink) Old 07-10-2015, 09:39 PM Thread Starter
Wondering what cold air intake I should run on the 2015 I'm sure they are not all the same thanks
2013 GMC 2500HD-2015 GMC all terrain hd
ssdmax13 is offline
post #2 of 25 (permalink) Old 07-10-2015, 09:46 PM
SilverGorillaLML's Avatar
This is a High Powered sited dedicated to Chevy and GMC Duramax Diesel Truck Owners. Welcome! - Search Results for lml cold air intake
"Flat Back Gorilla" Daily/Tow rig- 04 GMC Sierra LB7 CC Flatbed/Tune/Exhaust
"Empty Pockets" Race/Pulling truck- 2012 CCSB Cummins/Built Engine/
Full Billet 48RE Swap controlled by PCS2000/
B&M Ratchet shifter/Big fuel/Big air/Lowered
post #3 of 25 (permalink) Old 07-10-2015, 11:25 PM
Thatmarkguy's Avatar
2011 Chevrolet Silverado 2500 HD LTZ Crewcab Duramax/Allison
DPF Delete, MotorOps Tuning, Corsa Muffler
5000K HID Light Kit, Fass 150 Lift Pump
305/55/20 Cooper Zeon LTZ
Thatmarkguy is online now
post #4 of 25 (permalink) Old 07-11-2015, 12:40 AM
Dirtymax6384's Avatar
The s&b is the go to intake but the stock air filter provides amazing filtration and supports 500hp no problem
2012 phantom efi live by kory dpf delete wcfab s400 kit with an s469 wherli cp3 conversion with exergy sportsman idler/pitman arm brace cognito tie rods fass pump built ats transmission lowering shackles 20x10 American force 305-50-20 toyo proxys and black 4" duals to 8" black tips axle dumped
Big thanks to PPEI, WCFAB, and CALVINS
581rwhp stock turbo and injectors
Best1/[email protected] 1.82 60ft
624rwhp 68mm vvt and stock injectors
best 1/8-never tested
658rwhp(turned down)s469 stock injectors
The wifes:04 ECSB LLY LT 4X4: Built Motor, Built Trans w/ 1058, s472, 60% exergy, Wicked Level 3 CP3, Built Front End, Rancho 9000, Traction Bars
11.85 @ 115, 7.56 @ 92
colton cockrell
Contact me now! 512-734-6384
AMSOIL - Diesel Performance - EFI Live by Kory Willis - MCC Custom Tuning by Kory Willis
Dirtymax6384 is offline
post #5 of 25 (permalink) Old 07-11-2015, 01:25 AM
DaJokr's Avatar
If your not planning on pushing past the abilities of the stock charger, save your money and stick with stock.
If your hell bent on parting with your money, then s&b like Colton said.
Beastly Build
LBZ Drag Racing
2006 GMC LBZ 4x4 CC/SB
1/4 Mile [email protected]
1.793 60'
DIED 09/19/17 11:02AM
REVIVED 12/21/17 3:57PM
DaJokr is offline
post #6 of 25 (permalink) Old 07-11-2015, 01:29 AM
The only advantage you'd really get from an S&B would be the ability to check your filter without having to open the box because it has the clear lid on it and it does look a bit better in the engine bay compared to the stock box
colton cockrell
post #7 of 25 (permalink) Old 07-11-2015, 04:33 AM
lparrill's Avatar
I think another turbo is the best intake
Levi
04.5 GMC CCSB LLY - Code name- PPRWT - Built Motor, Built Trans, Big Twins, Dual CP3, etc - HSP l Industrial l LDS l Burkette Racing l Danville l Suncoast l Socal l Bullsye
05 Chevrolet CCSB LLY - ADII, Profab EGR delete, 4" exhaust, Built trans
lparrill is offline
post #8 of 25 (permalink) Old 07-11-2015, 07:33 AM
I would get an s&b. An lml gained 40 hp on stock tuning with just the intake. Rob from atp is doing some testing on a dyno. I know you have newer model but I would get one anyways. That's just me.
LBZ
SoCalMike is offline
post #9 of 25 (permalink) Old 07-11-2015, 07:44 AM
830king's Avatar
Wow 40 hp from a cai, that's insane! I didn't realize the lml intake was that bad. I guess the only good stock intakes are on the lbz/lmm trucks.
My name is Dan, I drive a 2005 2500hd ccsb lly 4x4, victory red, Efi live Robs trans safe tunes, Edge cts w/pyro, Silverline 5" exhaust, Magnaflow downpipe, LML ds manifold, Arp head studs, S&b turbo inlet, S&b cai dry filter, Ppe shim kit, drilled fuel rails, B&w turnover gooseneck, Ma welded waterpump, Profab egr delete, Fass titanium 150, Beans fuel sump, Ma pump rub plate, 285/75-16 duratrac on stock rims, Kryptonite tie rod & centerlink, Kryptonite sway bar end links, kryptonite lower ball joints Rare parts extreme duty pitman and idler arms, Dhd steering brace, Alligator 5/8" trans lines.
830king is online now
post #10 of 25 (permalink) Old 07-11-2015, 07:47 AM
I would still get one. I have a lbz...
LBZ
