Wehrli LML CP4 conversion - Page 3 - Chevy and GMC Duramax Diesel Forum
 3Likes
post #21 of 29 (permalink) Old 05-13-2017, 11:57 AM
SheeB's Avatar
Originally Posted by FC5452 View Post
If you cut the end of the hose at a 30 to 40 degree angle you won't get a condensation build up to freeze a 3/4 inch hole shut.
I don't live in Alaska or Canada where temps get in the sub zeros but here in the mountains we do get below freezing d have not plugged mine in 6 years
Sent from my iPhone using Tapatalk Pro
Thanks again FC5452.
FC5452 likes this.
_____________
2012 LML CCSB Deleted w/Motor Ops tuning, 5" Flo Pro w/3" DP.
SheeB is offline
post #22 of 29 (permalink) Old 06-02-2019, 08:58 AM
Guys I am stuck here. I got the Wehrli kit and cannot figure out how the fuel feed line hooks up if you are bypassing the factory filter. I have read the directions several times and just can't picture what it is saying. I have also dug around here and google to no avail. Can anyone help me out? trying to get this thing finished up today please help!
Dubs Chops is online now
post #23 of 29 (permalink) Old 06-03-2019, 05:35 PM
J83
J83's Avatar
if the only issue is bypassing the filter, the best solution would be to not bypass the factory filter, the added water separation, filtration and ability to prime the fuel system is handy and theres really no benefit in removing it.
I do not know the answer to your question as asked though, so all i can do is give you the above advise and a bump.
TCM & ECM Tuning by MotorOps
Y Bridge delete with turbo back exhaust
J83 is online now
post #24 of 29 (permalink) Old 06-04-2019, 05:15 AM
Ship4Brains's Avatar
The supply will go straight to the pump.
Mike
2016 Denali
Retrax Bed Cover
SDP High Flow Kit
SDP CP3 Conversion w/Exergy Sportsman
AD4G 100
5" Flo Pro Exhaust
Pro Fab 3" Downpipe
Pro Fab Tow Flow pass up pipe
HSP Traction Bars
Ship4Brains is offline
post #25 of 29 (permalink) Old 06-05-2019, 12:42 PM
Seems like a lot of extra harline running all the way over to where the filter used to be only to run a soft line back to the pump. I short hardline would have been nice.
thanks for the info guys.
post #26 of 29 (permalink) Old 06-05-2019, 12:57 PM
J83
J83's Avatar
its not exactly a cheap tool for something your probably going to use once, but you could get something like this and make your own hard line to the size and shape that works for you. Or im sure you could fine a place to make it for you for less.
https://www.amazon.com/Tube-Beading-...gateway&sr=8-2
J83 is online now
post #27 of 29 (permalink) Old 06-07-2019, 07:49 AM
Thats actually a pretty good idea. I could keep everything down in the valley. Heck I could even just cut the original one and re-bead it.
post #28 of 29 (permalink) Old 06-10-2019, 07:56 AM
big_turbo_lml's Avatar
You guys should check out the low pressure line I made / sell for bypassing the fuel filter on CP3 converted LML trucks. Look up John C Garage if you're on instagram for pictures and examples.
Also it can be purchased here.
https://underdog-diesel.com/collecti...-2011-2016-lml
It eliminates that two piece metal line under the y bridge. It will bypass the fuel filter, or can be used with the fuel filter with enough fuel line, but it definitely cleans thing up a lot!
Also, I'm the creator the CP3 conversion sticky thread here.
2016 LML Deep Garnet Denali - John C Garage Drop shackles, Airdog 165 4G, G&R Sump, AFE 5" exhaust, MBRP downpipe, MotorOps tuning! 12.8 @ 105 Stock turbo CCSB
2017 L5P Summit White Denali GONE
2012 LML MotorOps tuned, Fleece Big Turbo, 11.5 @ 119 GONE
2006 LBZ GONE
@John_C_Garage on insta
big_turbo_lml is offline
post #29 of 29 (permalink) Old 06-10-2019, 05:51 PM
denarli6.6's Avatar
If you go to the Wehlri website there are instructions for the LML CP3 conversion for either the street or race series conversion under the installation tab on home screen.
2016 LML Denali 2500
Reverse level with Mcgaughy's drop shackle set a 1"
Bilstein 5100 all-around
22x10 American Force Flux black w machined
Wehrli S300 kit w/ 66mm SXE
Wehrli CP3 conversion Race series with 10mm stroker
Profab Manifold & Up-pipes
denarli6.6 is offline
