Ez lynk and ppei tuning available now - Page 68 - Chevy and GMC Duramax Diesel Forum
 176Likes
post #671 of 689 (permalink) Old 01-23-2018, 01:28 PM
DuramaxForum Guru
Originally Posted by PragmaticSkill View Post
Subbed for research.....getting tired of things like "poor quality diesel exhaust fluid" and other faults. Want to clear them myself.
The EZ Lynk is the best tuning platform on the market. Most of the major tuners now offer it as an option. If we can help answer any questions please let me know.
PragmaticSkill likes this.
Meyerperformance is offline
post #672 of 689 (permalink) Old 01-30-2018, 09:26 PM
Cjhartshorn92's Avatar
Anybody have issues with turbo surging/excessive cycling? When I'm cruising at a constant throttle input and maintaining speeds, my VGT will cycle back and forth from holding ~10 psi boost down to 3ish then back up. VGT command seems to fluctuate up and down. Rail pressure holds steady when this happens.
Cjhartshorn92 is offline
post #673 of 689 (permalink) Old 01-31-2018, 10:59 AM Thread Starter
unknown known most
8ualive's Avatar
Have you logged it and sent it to the tuner?
2015.5 Denali 2500 on 35's at factory height...sold
2008 lmm......sold
2003 gmc RCSB with 6.0 and 4L80 for now...
2000 Camaro ss with 5.3 and s480 billet wheel...
8ualive is offline
post #674 of 689 (permalink) Old 02-16-2018, 09:25 AM
PragmaticSkill's Avatar
So I'm close to pulling the trigger on EZ LYNK with PPEI. I wont be deleting right away. My question is, will this setup allow me to clear the dreaded "diesel exhaust fluid poor quality" fault. I've been in limp mode before and I don't want to go back.
I will delete eventually, but will this keep me out of trouble till then?
PragmaticSkill
2013 Chevy Silverado 2500HD LTZ
Duramax 6.6L LML Stock
Michelin Defenders LT275/65R20/E
2019 Puma Palomino 31FK
PragmaticSkill is offline
post #675 of 689 (permalink) Old 02-16-2018, 09:40 AM
Hyme's Avatar
Yes it will. You can remove it entirely or keep it
2016 Denali HD
Leveling Kit
LED Fogs
Video in motion
Ez lynk with PPEI 200hp tune (switch not yet installed)
Fass 165 with G&R sump
S&B wet intake
5" Flo-pro
Deviant blocker plates
35x12.5 Mud Tires
HornBlasters Train Horns
Hyme is offline
post #676 of 689 (permalink) Old 02-16-2018, 09:48 AM
Thanks Man!
PragmaticSkill
post #677 of 689 (permalink) Old 02-16-2018, 10:18 AM
Showtime87's Avatar
I would disagree with the previous statement. If you load a deleted tune on a non deleted truck, my understanding is, you will be in a not so good place. I’m fairly certain the dpf must be removed. Now ez lynk does have emissions intact tuning, but I don’t see how that would remove the code.
2012 D-MAX LML
4" cognitio lift with uniball upper arms and fox remote shocks all the way around. Cognitio HD tie-rods. Full delete with 4" flo-pro exhaust and efi tuned by korywillis at PPEI. 54" curved rough country light bar.
35x12.5x20 Toyo Open Country MT
amp research steps
Showtime87 is offline
post #678 of 689 (permalink) Old 02-16-2018, 11:02 AM
I wasn't even planning on loading a tune. Is that what you do to clear a fault? The website says:
The EZ LYNK AutoAgent will support the following vehicles for custom tuning:
•GM: 2011 – 2016 6.6L Duramax
•ECM Tuning
•Read & Clear Diagnostics Trouble Codes
•Record Live Data & Playback Data Logs
•Apple iOS & Android Smartphone support
•Cloud Based Tuning Platform
My primary need is to clear faults/ codes associated with DEF / emission problems. Man, this is hard to wrap my head around.
PragmaticSkill
post #679 of 689 (permalink) Old 02-16-2018, 11:13 AM
Showtime87's Avatar
•ECM Tuning
If all you want to do is delete the code, then yes. It will work. But, if there is a problem. It will just come back. Deleting a code doesn’t delete the problem.
2012 D-MAX LML
amp research steps
post #680 of 689 (permalink) Old 02-16-2018, 11:14 AM
Showtime87's Avatar
There are far less expensive ways to just delete CEL code. Any obd II reader will do that.
2012 D-MAX LML
amp research steps
