EGR delete without DPF removal? - Page 2 - Chevy and GMC Duramax Diesel Forum
 8Likes
post #11 of 28 (permalink) Old 03-29-2019, 08:09 PM
SilverGorillaLML's Avatar
Yes
Race/Pulling truck:2012 CumminGs/Built 6.8L/Big air/Big fuel/48RE Swap/PCS 2000/B&M Gated shifter
Kid hauler: 08 Lincoln navigator
Work/dd: 02 4.3 RCLB Silverado
SilverGorillaLML is offline
post #12 of 28 (permalink) Old 03-29-2019, 08:49 PM
Sierraluva's Avatar
Yup.
🤘 Kennedy fuel system support hardware, CCM front Diff Drop, some LEDs to make night into day, got some big ol 20's and wide ass tires and a nice display to show me what's up under the hood-
2012GMC2500CCSB
Sierraluva is offline
post #13 of 28 (permalink) Old 03-29-2019, 08:51 PM
Sierraluva's Avatar
Also that def tank comes out fairly easily too. Just run it empty first.
2012GMC2500CCSB
post #14 of 28 (permalink) Old 03-29-2019, 10:13 PM Thread Starter
Thanks for help. One more question, can I replace DPF with pipe and keep stock exhaust? Is Dpf delete pipe available?
2015.5 GMC Sierra Denali 3500 HD DRW
GMCdiesel is offline
post #15 of 28 (permalink) Old 03-29-2019, 10:19 PM
Yes. Xdp sells one for a good price. They are a vendor here also. Give them a shout
post #16 of 28 (permalink) Old 04-12-2019, 07:25 PM Thread Starter
Originally Posted by mstein86 View Post
Remove the DPF and keep the cat, that's what I did. Sounds great and doesn't stink...
What you do with wires going to cat? I see you are running Magnaflow exhaust, do you have muffler on your truck?
post #17 of 28 (permalink) Old 04-13-2019, 05:58 AM
mstein86's Avatar
I filled the plug with dialectic grease and put it in a little sandwich bag and zip tied it up. Yes I have a muffler. Iím running a cat, muffler, no DPF.
mstein86 is offline
post #18 of 28 (permalink) Old 04-13-2019, 06:25 AM
D_R_C's Avatar
I filled the plug with dialectic grease and put it in a little sandwich bag and zip tied it up. Yes I have a muffler. I’m running a cat, muffler, no DPF.
Dan
EFILive TCM Duramax Tuner
DHD PCV Re-Route
AirDog 4G100
D_R_C is online now
post #19 of 28 (permalink) Old 04-13-2019, 07:04 AM
407driver's Avatar
I can unplug 3 plugs from EGR, remove DPF, keep CAT and get EFI live tuner and I'll be good to go? I need to do it over a weekend, is it possible?
You can but it may create one of two problems in the future:
1. the EGR valve could still open with enough pressure and it still put all that soot into yrou engine (The reason to shut off the EGR in the first place will be defeated). A simple cheap blocker plate will prevent this
2. The EGR Cooler can leak and that will put coolant into your cylinders. NOT good. Sinister makes a good delete kit for around 250 or so.
IMO, best choice, remove EGR system (in addition to DPF) Tune to prevent Limp Mode.
KEEP the parts Just in case...... Should you ever have to put them back it would be VERY expensive to have to buy them again
407driver is online now
post #20 of 28 (permalink) Old 04-13-2019, 12:04 PM Thread Starter
Thank you all.
Similar Threads
Lmm dpf delete without egr delete? Dylan L 07.5-10 LMM Duramax Powertrain 9 03-13-2016 10:17 AM
Egr blocker plates vs egr delete vs egr delete w/ up pipe LML'12 11-16 LML Performance Parts Discussion 22 05-21-2014 12:07 PM
Egr/dpf delete without tuner Bob32racing 07.5-10 LMM Duramax Powertrain 3 03-12-2014 08:44 PM
How bad is it to drive my lmm without dpf, cat, and egr without a tuner? legitwhiteboy17 07.5-10 LMM Performance Parts Discussion 4 09-03-2013 09:08 PM
Dpf pipe removal with no dpf delete ??????? chevyman07 07.5-10 LMM Performance Parts Discussion 3 07-21-2010 07:51 AM
