Need help deleting LML - Chevy and GMC Duramax Diesel Forum
 4Likes
post #1 of 38 (permalink) Old 04-10-2019, 08:31 PM Thread Starter
I sent an email to PPEI asking to purchase a tune for my LML a few days ago and have not heard back yet. I know I can buy the EGR delete from a few different sources and there are numerous options for exhaust to delete the DPF as well. I really don’t know which ones to avoid or advantages of one over the other. The biggest issue is the tune. Is there a secret knock when ordering a tune or a special handshake to get in the door?
I thought about doing the H&S mm just to get the code throwing junk off my truck since I’m ok staying close to a stock tune.
If anyone knows a shop around Little Rock or even Memphis, I could go straight to the source.
Bono is offline
post #2 of 38 (permalink) Old 04-11-2019, 05:14 AM
Ship4Brains's Avatar
Troll?
Mike
2016 Denali
Retrax Bed Cover
SDP High Flow Kit
SDP CP3 Conversion w/Exergy Sportsman
AD4G 100
5" Flo Pro Exhaust
Pro Fab 3" Downpipe
Pro Fab Tow Flow pass up pipe
HSP Traction Bars
Ship4Brains is offline
post #3 of 38 (permalink) Old 04-11-2019, 06:10 AM
SilverGorillaLML's Avatar
Flopro exhausts fit great. Stay away from h&s. Get ahold of mark at synthetic motorsports. Tell him Nic sent you.
2012 QCSB/Built 6.8L Cummins/48RE/Gated shifter
SilverGorillaLML is offline
post #4 of 38 (permalink) Old 04-11-2019, 07:37 AM Thread Starter
1. Not a troll.
2. Read a lot about Kory Willis and PPEI and being the way to go, so I was surprised I’ve heard nothing back yet.
3. The H&S mm would be an off the shelf setup I can just buy and delete the extra parts GM installed on my truck. Since I don’t want a crazy tune for power, I didn’t know if a box tune would be fine and possibly wouldn’t see the benefit of a custom tune.
I know there are thousands of threads, I read a lot before signing up. When it comes to actually doing the delete, I’m not sure who to get in touch with.
Bono is offline
post #5 of 38 (permalink) Old 04-29-2019, 07:53 PM
I just had mine done at Southern Fried Motorsports here in SC. (I know, not the location) I have the H&S b/c it was easy and I deleted all the things (EGR, Cat, DPF) and added exhaust and CAI. I'm using the street tune and holy crap what a difference. My only complaint is that the turbo whistle (more like a whine) is loud...borderline obnoxious. I'm on here tonight looking for a way to quiet it down...good luck!
bigbert is offline
post #6 of 38 (permalink) Old 04-29-2019, 08:28 PM
Magnaflow muffler or fte resonator.
post #7 of 38 (permalink) Old 04-29-2019, 10:53 PM Thread Starter
I have a PPEI EFI Live Autocal and Deviant EGR delete with up pipe waiting to be installed. The exhaust is a P1 SS downpipe back with tip and muffler.
On the tune I went with the 60 hp and TCM based on the recommendation of PPEI. I wanted to buy the FloPro SS860 but couldn’t find one and it seems like the DPF and EGR delete options are a little thin right now.
Sent an email back to PPEI asking if I can run the tune with just the exhaust swapped out. I’m not sure if I’ll get the EGR done this weekend as well since we are on the road until this fall.
Bono is offline
post #8 of 38 (permalink) Old 05-07-2019, 12:12 PM Thread Starter
Tried to swap the exhaust this weekend. We are not at home so I had gravel, not concrete. I don’t have jack stands, don’t have metal cutting materials, and I do not have any 1/2” sockets.
I’m going to borrow a sawzall or buy a circular saw blade to cut the extension pipe to the correct length.
Before I rent a stall with a lift on Friday, what size sockets do I need? I have a 1/2” breaker bar and 3/8 sockets as well as a 1/2 impact. So far, I know I need a 15mm deep well for the exhaust. What size is the trans cross member?
No, I’m not cutting it out. We move too often to risk needing to buy it all back. I just want to limit the extra tools I need to buy and don’t want to be half way through when I need something I don’t have.
Thanks
Bono is offline
post #9 of 38 (permalink) Old 05-07-2019, 12:20 PM
J83
J83's Avatar
On the tune I went with the 60 hp and TCM based on the recommendation of PPEI. I wanted to buy the FloPro SS860 but couldnít find one and it seems like the DPF and EGR delete options are a little thin right now.
Sent an email back to PPEI asking if I can run the tune with just the exhaust swapped out. Iím not sure if Iíll get the EGR done this weekend as well since we are on the road until this fall.
from the searching i did for my truck, your EGR delete options are basically a Y bridge install. There are or were a couple pre 15.5 block off plate kits still around from deviant and sinister as of a month or two ago but the market is very thin. the Y bridge is expensive, but it will completely remove all of the EGR mess with no block off plates or extra bellows to worry about.
J83 is online now
post #10 of 38 (permalink) Old 05-07-2019, 12:27 PM
J83
J83's Avatar
Thanks
Im not sure what size those bolts are, knowing GM, they are probably 15 or maybe 17 or 19 mm but im not sure. The rest of the sockets i used were 8,10,12,13,15, but i didnt pull the cross member. I found having those sizes in 1/4 and 3/8 deep and shallow to be quite helpful. This is what an up pipe bolt does to a 1/2" drive snap on socket.... My point being, if your not at home, it would be a lousy place to have to call it a day part way through.... ask me how i know.
J83 is online now
Similar Threads
Deleting my LML help Muzbomb 11-16 LML Performance Parts Discussion 39 05-10-2019 05:52 AM
Deleting my LML dirtymaxxx03 11-16 LML Performance Parts Discussion 31 08-04-2014 04:49 PM
Deleting my 2011 LML this weekend maineloggerlbz 11-16 LML Performance Parts Discussion 1 09-09-2013 09:21 PM
Deleting LML suggestions redmist 11-16 LML Performance Parts Discussion 13 06-12-2013 08:35 AM
Deleting LML redmist Aftermarket Mods. 17 06-09-2013 07:12 AM
