LML CP3 Conversion - Chevy and GMC Duramax Diesel Forum
 5Likes
  • 1 Post By 1TRIKHD
  • 2 Post By SilverGorillaLML
  • 1 Post By SilverGorillaLML
  • 1 Post By Dm23
post #1 of 10 (permalink) Old 05-17-2019, 12:02 PM Thread Starter
LML CP3 Conversion
Hello, I am need not some advice. I have searched and searched and searched and couldn't find the answers that I feel would help me make the correct decision. I have a 13 lml that's tuned and deleted and want to do the CP3 conversion. I am trying to decide between a Cp3 or 10mm Cp3. Reliability is main reason for the conversion since my warranty has expired but would like to see some performance benefits. The questions I have:
1. What is the max HP a standard Cp3 can make in an LML?
2. Would simply changing the Cp3 (not adding turbo or anything else) increase performance?
3. If the Cp3 does increase performance, would I see any additional increase by going with a 10mm without changing anything else?
The only additional wish list items I have for the motor is a drop in (stealth) turbo at some pint in time. I appreciate any insight on this!
Thanks!!!
bostonhoff is offline
post #2 of 10 (permalink) Old 05-17-2019, 01:47 PM
DuramaxForum Guru
1TRIKHD's Avatar
Location: Where Loggers do it better in the Woods. PNW Son!
Thanks!!!
This is what I would do if I was in your shoes.
http://www.sdptwins.com/exergy-sport...onversion-kit/
Give Scott a call and he can answer all the questions you have pertaining to your needs as far as reliability and performance.
Sent from my VS988 using Tapatalk
CDmax16 likes this.
2006 Victory Red CCLB LT3 LBZ
Tuned by Blake Crenshaw
SDP Fully Built Trans w/ Billet Goerend G Converter
S472 SX-E.87/1.0ar sitting on a Wagler street intake W/ a twisted pedestal
Stock Sticks
Special thanks to Scott with Screaming Diesel Performance
Blake with Unleashed Duramax tuning
1TRIKHD is online now
post #3 of 10 (permalink) Old 05-17-2019, 04:26 PM
SilverGorillaLML's Avatar
Stock lbz or lmm cp3 and sportsman will do mid 600s depending on tuner and injectors. A 10mm will do 800s. So if you have that power goal in mind go with a 10mm. It doesnt sound like it so get a stock, cp3k or sportsman pump. All the cp3k and sportsman do is fuel past 3200 rpm which is where a stock cp3 falls off.
Rethink your stealth turbo. They're shit. Know plenty of guys who have destroyed them in less than 10k miles and know a guy who just put one on and is already pushing oil. Go with a modded vgt from mark at danvile performance. Best vgts they make hands down no questions about it.
1TRIKHD and CDmax16 like this.
Nic
2011 GMC Sierra 2500 cc/sb LML Quicksilver
Tiny s4002 Banks performance dpf's, 2.5 egr coolers, 3 Def tanks filled with meth water from Walter White, wcfab thing things, custom hot air intake, exergy thing thing, sdp thing things
garden hose ran from fass, rancher tuned, 16 John deere injectors, 36x28forces with -10,000 offset
Wiles Diesel Performance
Woodstock, Va
post #4 of 10 (permalink) Old 05-17-2019, 07:24 PM
DuramaxForum Guru
1TRIKHD's Avatar
I agree also with Nic on the vgt turbos from Danville.
Stock Sticks
post #5 of 10 (permalink) Old 05-17-2019, 07:35 PM
Well of course you do russ I'm always right duh
1TRIKHD likes this.
Nic
Woodstock, Va
post #6 of 10 (permalink) Old 05-18-2019, 01:20 PM Thread Starter
Thank for the reply’s I really appreciate the insight and feedback. I will most definitely be looking at the Danville! Is a cp3 sufficient for that turbo or is a 10mm. Thanks!
post #7 of 10 (permalink) Old 05-18-2019, 04:10 PM
CDmax16's Avatar
Like Russ said earlier, I think the Exergy Sportsman with the SDP kit will work perfect for what you have now and when you put a Danville turbo in later.
Wehrli intake bridge and AFE IC piping,Edge Insight, AirDog II 165,SDP resonator delete, Mishimoto pcv catch can,Motorops TCM+ tuning, MBRP down pipe,Recon led tail lights and third brake light,
Kryptonite uca’s & tie rod sleeves, CCM diff drop,Fox 2.0 reservoirs, steering stabilizer, CalTracs,
Cognito PISK and heavy duty sway bar links, AirLift bags...
CDmax16 is offline
post #8 of 10 (permalink) Old 05-18-2019, 04:12 PM
Stock cp3 or sportsman will be fine
Nic
Woodstock, Va
post #9 of 10 (permalink) Old 05-19-2019, 08:24 PM
Just did the cp3 conversion on my LML. Along with Danville’s 65mm. I went with Fleeces PowerFlo 750 10mm pump. So far so good. 👍🏻
Kdogc10 likes this.
White 2012 2500HD LTZ Crew cab Short bed, 5" Mbrp W/O Muffler down pipe back,PPEI by Kory Willis,Rhino Lining,Diamond Eye DownPipe,FASS Titnium Series 165gph, Wehrli Custom Fab Intake bundle EGR Delete, PCV-reroute
GarrettHeyyaa
Dm23 is offline
post #10 of 10 (permalink) Old 05-19-2019, 08:27 PM
If you plan on doing the cp3 yourself there’s a thread on here from a few years back that helped me out with the installation. Also truck trend did a write up as well. Both were very informative.
GarrettHeyyaa
Dm23 is offline
Similar Threads
CP3 Conversion - Can I buy any CP3? jtharmon 11-16 LML Duramax Powertrain 3 08-29-2018 01:00 PM
LML CP3 conversion Beebe 11-16 LML Performance Parts Discussion 56 09-08-2017 07:26 AM
2011 lml WC fab twin turbo and cp3 conversion build frederickwisby 11-16 LML Performance Parts Discussion 68 06-29-2015 07:49 PM
