Hydroboost??? - Page 2 - Chevy and GMC Duramax Diesel Forum
 1Likes
post #11 of 12 (permalink) Old 09-24-2019, 02:32 AM
407driver's Avatar
Originally Posted by J83 View Post
True, theres some guys on here though that spec a special GM puller for our trucks and say that NOTHING else works so i wanted to make sure we are all on the same page that the cheapo puller available at every auto parts store everywhere works just fine.
YES, it HAS to be a GM puller/presser like the one you pictured. That is what they "loaned" me. Actually not a loan, I paid for it and was refunded when I returned it within 24 hours, or if I did not return it in time, I then owned it.
It is actually a clever little tool, but I was not able to use it until I had the pump off. Likewise I was unable to get it to work to press the pulley on unless the pump was off the truck.
I did find a little trick that worked for me. When reinstalling the pump I "Hung" it on the center bolt in the front. Then I installed the two side bolts and that lined up the other two front bolts perfectly.
Prior to installing the side bolts no matter how i wiggled and jiggled I could not for the life of me get either of the other front bolts to start.
Also, for the uninitiated, start both the lines on the pump before installing it. leave them loose but with the threads started.
407driver is online now
post #12 of 12 (permalink) Old 09-26-2019, 06:49 PM
Just replaced mine about 1 month ago. Found a seal kit for it ,long story short seal kit was a waste of time. Had to take it off 2x and Ended up just replacing the unit anyway. Save your time and just replace it. Just my experience.
2006 LBZ
WC fab y bridge, inter cooler
EFI live with dsp5 switch
full EGR delete, down pipe
5 inch magna flow
Bilstein 5100
DBLD is offline
