2005 LLY injector issues - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By Timsduramax
post #1 of 7 (permalink) Old 01-17-2020, 07:29 PM Thread Starter
I have read a lot about injector wiring issues, I have done a lot of troubleshooting. Codes 201,202,203,204,205,206,207,208,2146,2149. Replaced connectors on injectors 2 and 7, inspected all wiring. Iím still having the same issue. Has anyone had both banks shutdown? Iíve been to a GM dealer and they couldnít diagnose. Brought to another shop and they couldnít diagnose either. It will run for several weeks then bam shutdown. When it was running we pulled and tugged on all the wiring and it wonít repeat. Any help would be greatly appreciated.
Thanks
Tim
Timsduramax is offline
post #2 of 7 (permalink) Old 01-17-2020, 10:09 PM
Check the wiring that is secured to the alternator bracket.I put a piece of hose on my harness and resecured it. Also check the wire harness connector bracket above left engine valve cover; may have a rub from a bolt. May want to check your grounds and wire harness connectors are secure. You can get a wiring schematic from GM upfitter. Good luck.
2004 Chev Silverado LT 2500hd 6.6 LLY
Oilcoolerbender is offline
post #3 of 7 (permalink) Old 02-04-2020, 01:35 PM Thread Starter
Got another code today P1293A.
post #4 of 7 (permalink) Old 02-05-2020, 12:20 AM
Did you fix the other codes. May have a bad FICM.
post #5 of 7 (permalink) Old 02-05-2020, 06:49 AM
Former GM Tech and parts
DMAXfirefighter's Avatar
Sounds to me like a ficm issue. Got one you can pull off any try?
John Deere Service Manager
DMAXfirefighter is offline
post #6 of 7 (permalink) Old 02-10-2020, 09:20 AM Thread Starter
Replaced FICM. Truck runs great.
Thanks for the information and ideas.
Question: If I remove the catalytic converter and delete the EGR. Will I gain any HP.
Oilcoolerbender likes this.
post #7 of 7 (permalink) Old 02-10-2020, 10:53 AM
Getting rid of the catalytic converter will open the exhaust up and let it breathe better. A full exhaust will help more than just removing the cat, but that is getting harder and harder to do with the clinching grasp of EPA enforcement. EGR delete will help as well, so it could free up a couple horses between the combination of them
