No brake lights with new brake switch & bulbs - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 06-03-2019, 07:46 PM Thread Starter
DirtymaxTowpig's Avatar
Hey guys. New to this but not forums by any means. At this point I’ve checked all fuses and even replaced the good brake (stop) fuse with another good one, new bulbs and a new brake switch! Still no brakes tail or 3rd light! It’s a new to me 07 Sierra 2500 LBZ. All other lights work. The cruise control doesn’t else works also. I get no cruise light either, let alone it setting. Not sure what to check now. I followed lines to tail lights and seem good. I’m gonna try all fuses again... ugh
"Mucho take it easy" - N.L.
2007 GMC Sierra CC SB SRW LBZ, cranked torsions with 18Ē ? Wheels and 285/65/18 BFG A/T KO2, stock everything else
DirtymaxTowpig is offline
post #2 of 7 (permalink) Old 06-03-2019, 08:34 PM
LHN...We ARE the Joneses
In the Instrument Panel Fuse Block;
you checked
VEH CHMSL
VEH STOP?
You just acquired it...with no working brake lights?
Or, it's a failure after they were working?
Hook'em_Horns! is offline
post #3 of 7 (permalink) Old 06-03-2019, 11:32 PM Thread Starter
you checked
VEH CHMSL
VEH STOP?
Check both of those and most others, twice! Even swapped them out just to be sure. I bought it this past Saturday. One owner, clean carfax. We checked everything! From cigarette light to wipers to 4LO-4HI to crawling under. My father and I agreed the little cosmetic things were worth the purchase... we missed the brake lights 🤦♂️ And cruise control. Got excited and forget to check cruise till about 100 miles out! Brakes we just missed! So I replaced the tail light bulbs. Changed out the brake switch and no brakes! It also wouldnít shift out of park. Swapped back and shifting was fine but still no brakes or cruise control!!! Any ideas of what check next? I just wanna drive it so bad lol. Thanks
post #4 of 7 (permalink) Old 06-04-2019, 04:14 AM
Does the Hydro-Boost unit look like it's a new one?
post #5 of 7 (permalink) Old 06-04-2019, 12:19 PM Thread Starter
It didnít look brand new. Pretty clean under hood... I am working doubles and with two small kids I have up and took it to my mechanic. I just need brake light working!!!! Iíll report back with results. He said he gonna put in an AC Delco brake switch too not the ďVatoZoneĒ one 😂
post #6 of 7 (permalink) Old 06-04-2019, 05:37 PM
That's a start.
Need to keep clear of the VatoZone for HD parts....never goes well.
post #7 of 7 (permalink) Old 06-05-2019, 10:33 PM
I assume the brake light switch in the '07 is the same as in my '04.5...
When you press on the pedal, there is a little slop in the eyelet from the hydroboost. Just before the brake pedal pin presses on the rod, it hits the brake switch. If there's not enough slop, the pin engages the rod from the hydroboost without engaging the brake light switch.
When replacing a hydroboost, it is sometimes necessary to hog out the eyelet so there's enough slop. (Others have shimmed the switch, but I think ensuring enough slop is the way GM intended it to work.)
It's something to check.
2004.5 Silverado 3500 SRW 4x4, D/A (LLY), Ext. Cab, Long Bed
engineer837 aux rad, TxC CAI, LBZ MP, Scangauge II, Nicktane aux filter head, KD lift pump, 2008 PS pump, 2011 hydroboost, Frederico Swaybars, Rancho 9000XL, Torklift StableLoads, BFG AT/KO2, Lance 835 Camper often in the bed.
jake111 is online now
