2008 LMM Black Smoke - Chevy and GMC Duramax Diesel Forum
2007.5 + (GMT 900) Non Powertrain--New Body Style-- Discussion 07.5 - 2010 Topics Not related to the Powertrain, interior, suspensions, body, wheels, tires, ect.
 2Likes
  • 1 Post By msteeler
  • 1 Post By GPappy
post #1 of 7 (permalink) Old 01-18-2020, 08:28 PM Thread Starter
Hello All - I have a 2008 LMM with DPF delete with H&S tune. I noticed recently that every time I take off from a stop light or give it a little more gas on the freeway I’m seeing black smoke. It’s done this before but it’s never been as noticeable as what I’m seeing now. Any ideas?
Thanks
msteeler is offline
post #2 of 7 (permalink) Old 01-18-2020, 08:47 PM
DuramaxForum Guru
lutzjk913's Avatar
Might try to clean the mass air flow sensor.
Joe
2008 CCLB LMM
13.39 @ 99.44 W/ 1.76 60í
456 HP 925 TQ
2003 RCLB LB7 ďUNDER CONSTRUCTIONĒ
The life of my truck
Pics of my truck
lutzjk913 is online now
post #3 of 7 (permalink) Old 01-19-2020, 02:37 PM Thread Starter
Thanks, just cleaned it. We’ll see.
msteeler is offline
post #4 of 7 (permalink) Old 01-19-2020, 03:20 PM
hdrolling's Avatar
Any loud hissing under the hood, could have a boost boot leak. Mine had a tear that I could only hear it while towing and as it got worse I started getting the black soot.
2018 3500HD LTZ DRW
My build thread https://www.duramaxforum.com/forum/b...lly-build.html
GM DRW club member #224
hdrolling is offline
post #5 of 7 (permalink) Old 01-19-2020, 05:45 PM Thread Starter
Haven’t noticed any hissing sound but I’ll check the boots. Thanks
hdrolling likes this.
msteeler is offline
post #6 of 7 (permalink) Old 01-20-2020, 05:24 PM Thread Starter
Guess I’ll have to pressure test it. I did a visual of the boots and didn’t see any cracks or tears. Started at the one at the back/top (sorry, don’t know the names), removed it, looked good. Checked the down pipe drivers side, no issues there. Then checked the boot at the bottom drivers side. Although it seemed very thin I didn’t see or feel anything. Moved to the passenger side bottom boot, that felt fine. Where that boot connects to the plastic tube that connects to the engine, that connection between the plastic tube and engine seemed a little lose where I could kind of twist it. Not sure if that normal since I’m not sure how you would tighten that.
msteeler is offline
post #7 of 7 (permalink) Old 02-09-2020, 02:20 PM
Originally Posted by msteeler View Post
Hello All - I have a 2008 LMM with DPF delete with H&S tune. I noticed recently that every time I take off from a stop light or give it a little more gas on the freeway Iím seeing black smoke. Itís done this before but itís never been as noticeable as what Iím seeing now. Any ideas?
Thanks
I had the exact same thing just happen to me. I am away from home so took it to a shop to have it looked at. They found a leak in a seal just before the inter-cooler. Not exactly sure which it was but they cleaned up the surfaces and reattached. Runs a lot better now and I can pull my 12K trailer without rolling coal like a semi. Like they told me, black smoke means un-burned fuel which is likely lack of air. I was happy they found what they did and that it was not the turbo.
YMMV
Greg
GoBlowSnow likes this.
2007.5 2500 LTZ CCSB
MBRP 4" Exhaust with Muffler
EFI Live AutoCal from Kori Willis
Suncoast GMax trans with ML Precision Converter built by Allseasons. (Waiting for time to install)
Pioneer X950BH Nav Radio
Mitex Speakers and Amplifiers (replaced Bose)
Leveled
285/70-17
GPappy is offline
