Blowing hot air, when activating is on - Chevy and GMC Duramax Diesel Forum
2007.5 + (GMT 900) Non Powertrain--New Body Style-- Discussion 07.5 - 2010 Topics Not related to the Powertrain, interior, suspensions, body, wheels, tires, ect.
post #1 of 6 (permalink) Old 04-06-2019, 03:58 PM Thread Starter
Ujoint's Avatar
So when I auto start it, it blows ice cold. When I put the key in it blows hot on the drivers side. All other are cold.
Read a few things saying it's a accuator of some sort, all settings are set to cold. Any one had to deal with this
Thanks
07.5 GMC 2500 LMM
2006 Chevy 2500 LT 6.6L LBZ 4x4
Ujoint is offline
post #2 of 6 (permalink) Old 04-06-2019, 05:19 PM
BAMAWHISTLER's Avatar
Bump, my ac goofy at the moment also
2006 LBZ 2500 CCSB 2WD
EFI LIVE, DSP5, Edge CTS & EGT probe, PPE airbox mod, AFE hotside pipe, PPE manifolds/uppipes, MBRP DP, MBRP 4" side dumped, Sinister coldside pipe, pcv reroute, Beans sump, Kennedy lift pump, dual filters, coolant bypass filtration, Nuc Motorsports Oil Bypass kit, LML 20s & 265/60R20s, tint, LEDS, some chrome
ALABAMA LBZ Build Thread
BAMAWHISTLER is offline
post #3 of 6 (permalink) Old 04-07-2019, 06:34 AM
D_R_C's Avatar
Do you have separate temp settings selected, driver side and passengers side, is auto selected, if it is deactivate auto, recirculate or allowing outside air in.
Make sure both drivers and pass are set at the same temp with this happening, to verify.
Mines auto off, no passengers side, temp set at 60 with recirculate.
Is the airflow for the passengers or floor or both.
If both then select passengers only and see what happens.
Dan
EFILive TCM Duramax Tuner
AirDog 4G100
DHD PCV re-route
D_R_C is offline
post #4 of 6 (permalink) Old 04-08-2019, 08:24 PM Thread Starter
Ujoint's Avatar
Ok. I have the dual settings for pass/ driver. I played with it today for a bit. When I first started playing with it it was blowing cold with drivers and pass going on recirculation, switched it to outside and went hot on drivers side. Shut off truck. Came back and started The truck and started playing again and it was hot on drivers side.
Makes no difference if it's on drivers only. It's hot on the floor, and facing vents, all others are blowing cold. With all settings set to 16°©️. I tried setting it 31°©️ and it was still hot😁
Hope this helps.
Thanks
Ujoint is offline
post #5 of 6 (permalink) Old 04-09-2019, 02:01 AM
D_R_C's Avatar
Try having the air temp set blowing at the driver not split between the driver/passenger and floor.
Also take it out of the dual setting and select driver only, NO passengers, this is suppose to make it even on both sides.
Select the coldest temp which on both of my trucks is 60* F, select re-circulate, if you allow outside air in this brings in warmer air mixing with the cold air.
It makes a big difference on mine, especially in 120*, and I never select AUTO.
With it being cold remote starting then warm after you put the key in, something is set wrong or defective.
The first thing I would do is to forget about the dual pass/driver setting, select driver, and select vents only no floor and vents.
Other than these suggestions I made, next would be the dealer or a shop that specializes in ac.
Dan
AirDog 4G100
DHD PCV re-route
D_R_C is offline
post #6 of 6 (permalink) Old 04-18-2019, 09:18 PM Thread Starter
Ujoint's Avatar
Other than these suggestions I made, <img src="http://www.mysmiley.net/imgs/smile/confused/confused0082.gif" border="0" alt="" title="confused0082" class="inlineimg" /> next would be the dealer or a shop that specializes in ac.
Tried all to the driver and didn't work lol, just the passager works. So she gets one vent and I get the other. Sharing is caring
Ujoint is offline
Similar Threads
Air con blowing out hot air Mark Wagner Gauges, Electronics and Wiring. 4 02-13-2019 05:57 AM
ABS activating at slow speed CapnDean 06-07 LBZ & LLY Duramax Powertrain 31 02-26-2014 05:05 PM
A/C is blowing hot air out of driver vents but not passenger glock-hater Gauges, Electronics and Wiring. 10 07-30-2011 12:32 PM
One Side Blowing Hot Air KEA General Discussion 3 07-08-2010 02:28 PM
A/C Blowing Hot Air F1-Fiddy 911 Problems Forum 4 08-26-2009 05:06 PM
