07+ trailer brake not showing up in DIC - Chevy and GMC Duramax Diesel Forum
2007.5 + (GMT 900) Non Powertrain--New Body Style-- Discussion 07.5 - 2010 Topics Not related to the Powertrain, interior, suspensions, body, wheels, tires, ect.
post #1 of 5 (permalink) Old 08-03-2019, 05:22 PM Thread Starter
henrys072500hd's Avatar
Factory installed controller, nothing comes up on the dash when I hook up the trailer nor when I push the brake controller buttons etc. No power to trailer brakes.
henrys072500hd is offline
post #2 of 5 (permalink) Old 08-03-2019, 08:49 PM
Has this ever worked in your truck? Did you check the fuses? Have you checked for codes? Do you have an ABS light in your dash? High mount 3rd brake light work? Cruise Control work? When you connect a trailer does the DIC say TRAILER CONNECTED? There are lots of problems with this system and knowing some of these answers may help solve the problem. One relatively simple remedy is to replace the trailer brake system relay located on the rear frame above the axle. Another is to replace the trailer brake pressure sensor on the master cylinder.
Ron Nielson
Ron Nielson is offline
post #3 of 5 (permalink) Old 08-06-2019, 04:50 PM Thread Starter
Yes brakes have worked in the past, years ago I even had the relay changed after I got a message to service brakes. I did put a used dash from a newer truck in a couple of years ago and have not used the truck to pull a trailer until now.
So far all fuses are OK. No ABS light on. 3rd brake works. Cruise works. No trailer connected message. No service trailer brakes message either. I pulled the plug off the back of the brake controller and with the key on checked for power but no pin showed power at the connector. I will search for a wiring diagram.
post #4 of 5 (permalink) Old 08-06-2019, 05:22 PM
The truck doesn't even recognize that you have a trailer connected. Solve that problem and you may have brakes.
GMUPFITTERS.COM has electric manuals in the bodybuilders section of the website. Use the search function to find the information you want.
Ron Nielson
post #5 of 5 (permalink) Old 08-07-2019, 11:12 AM Thread Starter
Thank you very much for all your help Ron. Since we have sold our 5th wheel travel trailer and won't be getting another I will just leave the brake system as is. Hope someone else will benefit from your help on here.
