Upper control arm bolt size????? - Chevy and GMC Duramax Diesel Forum
2011-2016 (Non Powertrain) Discussion of 2011-2016 topics not related to powertrain
post #1 of 5 (permalink) Old 12-12-2019, 07:12 PM Thread Starter
matt45648's Avatar
Nowhere is it indicated in the kryptonite instructions and I have searched everywhere. Ive tried a 23mm (largest metric I have) and its too small, a 1" is too big. What size do I need here? Im talking about the upper two cam bolts. 2016 chevy 2500
2016 Chevy 2500 Z71 LTZ
Fleece CP3, Airdog 165 4g, Beans sump, Sinister EGR delete, MBRP 5" turbo back, S&B intake, EZ Lynk by PPEI, Edge CTS2, Sinister PCV reroute, Sinister resonator delete
Kryptonite UCA'S, Fox 2.0's, suspensionmaxx keys and diff drop, 22" Fuel Blitz's wrapped in Nittos... rub-a-dub dub... scrub scrub scrub
matt45648 is offline
post #2 of 5 (permalink) Old 12-12-2019, 08:54 PM
rockn69's Avatar
Did you try a 15/16? That is slightly smaller than 24mm
2015.5 Chevrolet Silverado LTZ, Z71, SRW.
Summit White
rockn69 is offline
post #3 of 5 (permalink) Old 12-13-2019, 05:41 AM Thread Starter
matt45648's Avatar
So I ended up getting a 1" to work without any damage to the nuts or bolts... but I'd say you are correct. Man the Kryptonites are sure hard to squeeze into the mounts! Got one side done.... on to the other on saturday!
post #4 of 5 (permalink) Old 12-14-2019, 11:05 AM
rockn69's Avatar
Was in the shop so I checked what size, a 15/16, or 24mm both fit. A 1" is really sloppy, surprised you were able to break it loose without it spinning on head. I'd get the proper wrench when you're re-assembling.
Summit White
rockn69 is offline
post #5 of 5 (permalink) Old 12-14-2019, 11:13 AM Thread Starter
matt45648's Avatar
I was actually able to get them installed using the same 1" socket with no damage to the bolt head... must be pretty tough hardware.
