Dual Batteries - How does it work? - Page 2 - Chevy and GMC Duramax Diesel Forum
2011-2016 (Non Powertrain) Discussion of 2011-2016 topics not related to powertrain
 1Likes
post #11 of 19 (permalink) Old 12-14-2019, 03:55 AM
chevor's Avatar
Hook have you seen the positive terminals on this new trucks? Spider web of wires.
2010 Gmc 2500 Duramax 853,500 Odometer miles - sold Nov 2018
2013 LT CCSB SRW bought with 508,000 miles, now over 674,000 miles
2013 CrewCab and chassis with 9' Hillsboro aluminum flatbed 84,000 miles. - Sold Sept 2019
chevor-2010-gmc-2500-maintenance-log
Favorite book : The Richest Man in Babylon
chevor is offline
post #12 of 19 (permalink) Old 12-14-2019, 07:52 AM
NHfireDmax's Avatar
Originally Posted by redwngr View Post
If it's only for a few weeks I wouldn't even worry about it.
Of course a maintainer (as opposed conventional charge only device) isn't going to hurt.
There is a way to set them back to shipping mode and use even less power.
https://www.dieselplace.com/forum/at...130_204806.jpg
I see the bulliten is from 2014... Has anyone confirmed / used this on a L5P?
2019 Quartz Red Denali HD Chrome deleted
NHfireDmax is offline
post #13 of 19 (permalink) Old 12-14-2019, 08:29 AM
redwngr's Avatar
Originally Posted by NHfireDmax View Post
I see the bulleten is from 2014... Has anyone confirmed / used this on a L5P?
You made we curious enough to try.
Seems to works as advertised.
Start engine.
Activate flashers.
Foot on brake.
Key to 'crank' for 15 seconds.
'Transport mode on' message appears in DIC.
Battery icon on dash also shows in red. (Radio keeps playing...fan keeps running...)
Deactivates the same way.
DIC message 'Transport mode off'.
'Dismiss' button appears, battery icon turns off.
redwngr is online now
post #14 of 19 (permalink) Old 12-14-2019, 10:26 AM
Diesel Junky
DatCajunLMM's Avatar
So what is the point of transport mode
Sent from my SM-G973U using Tapatalk
A.J.
Driveway Built 08 CCSB Z71 LTZ
Perf. EFI 4"SS-Mbrp AD165II S&B RaceValve TransGo
Susp. Cognito 6" Susp. lift w/ Braces UCA's RareParts HD Rods Bilstein 5100's 35 Nitto TG MT
Ext. Debaged Bumper's and Grille Painted and Bedlinered by me AVS TailCovers Putco3rdLight Hid's L/F
Int.InsightCTS WeatherTech DUHA
Misc.Blocked Plugd Rerouted2PolishedCC OEM fuelfilterDELETE
DatCajunLMM is offline
post #15 of 19 (permalink) Old 12-14-2019, 10:37 AM
LHN...We ARE the Joneses
Reduce battery draw while in storage or in staging areas.
Hook'em_Horns! is online now
post #16 of 19 (permalink) Old 12-16-2019, 03:00 PM Thread Starter
Originally Posted by 407driver View Post
Since you just purchased it, this thread may be of interest/use to you in maintaining it.........+ some other useful information:
https://www.duramaxforum.com/forum/m...ew-owners.html
Yup, been through it. Good stuff. I have replaced all fluids except PS/Brake Boost - will probably wait for Spring on that one.
2013 2500HD Extended Cab, Duramax, 4WD
Stock drive line and fuel system.
David Jay is offline
post #17 of 19 (permalink) Old 12-19-2019, 04:32 PM
Babyhauler's Avatar
I would get out of the truck, close the door and not worry the batteries for even a month of sitting.
My spare 04 1500 (Old and Busted) sits for months at a time with an Interstate blem battery in it. Usually starts no problem. My 48 hp John Deere sits outside for months in the winter without running and starts fine.
Andy
2004 2500HD LB7, Crew Cab LT, 4 x 4, 252,000 mi, CTS2, MBRP exhaust dual outlet, no cat, PowerStop Brake Kit, B & W Turn over ball, Air Bags, CamLocker toolbox, 265/75-16 Cooper Discoverer AT3, 3rd set of injectors at 205K mi. 4th set inj Oct 2019, Lincoln Diesel 45% over SAC inj. New head gaskets & studs. New Turbo.
Babyhauler is offline
post #18 of 19 (permalink) Old Today, 04:50 PM
If you ever change batteries you have to, change both at same time. Your system is only as good as your weakest battery same goes for TV remote cant have 2 new ones and 1 bad one
Twilightzone is online now
post #19 of 19 (permalink) Old Today, 05:30 PM
J83
J83's Avatar
There's logic in the ecm to keep the starter from engaging when the engine is running.
depends on the year. Anti-grind is not a thing on all models.
J83 is online now
