Passenger side front tire hitting wheel well liner - Chevy and GMC Duramax Diesel Forum
2011-2016 (Non Powertrain) Discussion of 2011-2016 topics not related to powertrain
post #1 of 7 (permalink) Old 12-24-2019, 08:35 AM Thread Starter
Riley 1820's Avatar
What would cause wheel to contact rear side of wheel well? I have 275 70r 18e tires. Door panel sticker calls for 265 70r 18e tires. Stock height. No mods to suspension. Lifted tire on ground checked for movement, none. Is there a way to check upper control arms. Also this is only on pass. Side. Thanks in advance.
2012 3500hd srw 4 wd Jamco exhaust Kennedy dual lift pump Trifca bed cover B& W gooseneck hitch Western Diesel fuel filter relocation bracket
Riley 1820 is offline
post #2 of 7 (permalink) Old 12-24-2019, 08:36 AM Thread Starter
Riley 1820's Avatar
Ment to say upper control arm bushings.
post #3 of 7 (permalink) Old 12-24-2019, 10:55 AM
laplanteT41's Avatar
did you just replace you're tire's? if so they are .5 of an inch wider then 265's. That is what's causing it to rub. crank you're keys a little and it shouldn't rub anymore.
laplanteT41 is offline
post #4 of 7 (permalink) Old 12-24-2019, 11:01 AM Thread Starter
Riley 1820's Avatar
Yes I did just change tires. I had 285's on and dropped to 275's. So if I crank the keys a little does that raise height so front will be more level with rear?
post #5 of 7 (permalink) Old 12-24-2019, 11:04 AM
It will but it does not take much to change your wheel alignment. Being you just purchased new tires if you do turn your keys up a bit you might look at having the alignment checked again. Dean
Dean E is offline
post #6 of 7 (permalink) Old 12-24-2019, 11:08 AM Thread Starter
Riley 1820's Avatar
Thanks Dean. Will try to get that done this coming weekend.
post #7 of 7 (permalink) Old 12-24-2019, 11:18 AM
As Dean said you should get you're alignment checked once you crank them. But turning up the stock keys will make it more level with the rear.
2005 LLY Reg cab.
Mods- Studded, fully deleted, grade C gaskets, Empire diy Keyed crank, welded water pump, 20x10 Fuel Ignite wheels, 305/50R20 Toyo Open Country AT2 , HSP trac bars, Cognito control arms, sinister blue powder coat engine components, 07.5+ cab lights, SSBC rotors, up pipes, manifolds, 5 straight pipe, FASS 165, XDP sump, EFI live, Edge CTS 2, DHD ALILOCKER, DHD tranny brace, poly trans mount, merchant motor mounts, Suncoast converter, shift kit, Stock fuel.
