Cognito Upper Control Arm Bushings???? - Page 2 - Chevy and GMC Duramax Diesel Forum
2011-2016 (Non Powertrain) Discussion of 2011-2016 topics not related to powertrain
post #11 of 13 (permalink) Old 12-29-2019, 02:36 PM
Originally Posted by redneck47441 View Post
I think I have a bad bushing in one of my Cognito upper Control arms. Mabey from over greasing not sure what the cause is. They've only been on the truck 10k miles leveled with 33's. Question is when replacing them could I just jack up the front of the truck taking some of the load off and and unbolt the arm from the frame, slide it out and replace the bushings?
Been hearing a clunk in my front end recently. After doing some digging around with truck on hoist, we found a bad UCA bushing on the passenger side. I have the Cognito Ball Joint Tubular Upper Control Arm Kit with Dual Shock Mounts. SO... before I do something and find out its unnecessary, whats the best way to replace these? Is it as easy as doing what is mentioned above? Is re-alignment going to be necessary? Thanks!!
2008 GMC Sierra 2500 BLACK, SLT, C.C., 4X4, Loaded
EFI Live 5 Stage by Stellar Diesel, 4" MBRP Exhaust, Cognito Leveling Kit
LMM_HP is offline
post #12 of 13 (permalink) Old 12-29-2019, 02:37 PM
Forgot to mention, these UCA's were on truck when I bought it so I dont know how many miles are on them....
LMM_HP is offline
post #13 of 13 (permalink) Old 12-31-2019, 12:51 PM
Should have an alignment done anytime you mess with the front end.
mray is offline
