Banks Intake and Exhaust on the Way - Page 4 - Chevy and GMC Duramax Diesel Forum
2017-19 GM T-K2 Platform Performance Parts Discussion Discussion of Performance Parts For the '17 and up L5P Duramax Trucks No Advertising
 53Likes
post #31 of 54 (permalink) Old 05-06-2019, 11:00 PM
Mystaken818's Avatar
Why PM. Maybe we have the same questions 😜
Mystaken818 is offline
post #32 of 54 (permalink) Old 05-07-2019, 06:40 PM
1lunger's Avatar
It’s here! Can’t wait to install
Black HD likes this.
1lunger is offline
post #33 of 54 (permalink) Old 05-07-2019, 09:54 PM Thread Starter
UTEngineer's Avatar
Found a $3 plastic cap that fit perfect for the intake resonator delete at Lowes ... in the sprinkler section of all places.
Once you remove the stock intake boot the intake resonator wobbles around ... so I removed the funky stock rubber washer causing the wobble issue and securely reattached the intake resonator.
2019 Chevrolet Silverado 3500HD 6.6L Duramax (L5P) Crew Cab 4x4 SRW Standard Box High Country Loaded w/ Rear Entertainment Package, Fabtech 4” Suspension Lift w/ Heavy Duty Tie Rods, 35” Tires on 18x8.5 Vision Valor Wheels, Luverne Grille Guard w/ Parking Sensor Relocation Kit, Rhino Roll Bar (Sport Bar 2.0) w/ 8” Hella Off-Road Lights, Banks Derringer / iDash / Intake / DPF Back Exhaust, Fabtech Stealth Shocks w/ Front Limit Straps, Front & Rear Hellwig Sway Bars, Airlift Air Bags w/ Wireless Air, DuraFlap Mud Guards, S&B MAP Sensor Spacer, Kryptonite Heavy Duty Pitman and Idler Arm, Centramatics
UTEngineer is offline
post #34 of 54 (permalink) Old 05-07-2019, 10:01 PM Thread Starter
UTEngineer's Avatar
Pictures of the $3 cap installed. In my opinion, it looks cleaner leaving the intake resonator installed. I highly recommend installing the Banks boot and deleting the intake resonator. My truck actually lost most of the hesitation it previously had when I punched the gas from a stop ... I was shocked at the improvement this caused.
post #35 of 54 (permalink) Old 05-07-2019, 10:41 PM
How much louder would you say the truck is with the resonator deleted. I am probably one of the few who likes the fact that the trucks are so much quieter now. I had an 05 LLY, this truck is so much quieter
post #36 of 54 (permalink) Old 05-08-2019, 07:23 AM
defenestrator's Avatar
You can definitely hear more rumble with the Banks intake, but I'm not sure if the volume increase is due to the resonator delete or just a the larger filter in a less restrictive housing. My Yukon got louder with a K&N, so it may just be the larger filter addition. I also like it quieter, so I am going to put the resonator back on with the stock boot to see if it is noticeably quieter.
2017 Silverado 2500HD Z71 L5P
defenestrator is offline
post #37 of 54 (permalink) Old 05-08-2019, 07:41 AM Thread Starter
UTEngineer's Avatar
I ran mine with the stock boot for about a month ... definitely much quieter. There is definitely a low level drone sound with the intake resonator removed ... but nothing loud or annoying in my opinion. In my opinion the off-the-line hesitation tradeoff is worth the low level drone sound. I drive 30k per year for work so I also prefer the quiet ride ... so if it was annoying I would also put the stock boot back on. To each their own ... I recommend trying it both ways like I did and do what works best for you.
defenestrator and Mystaken818 like this.
post #38 of 54 (permalink) Old 05-08-2019, 08:47 AM
Agreed; better stated. Thanks.
UTEngineer likes this.
post #39 of 54 (permalink) Old 05-08-2019, 08:04 PM
Black HD's Avatar
Finished up the exhaust install. I will add that in order to get the clamps tight, I had to break out the 1/2" drive ratchet. Tightened them with a 3/8" and the pipes still had some play. I used 4" band clamps. Sorry for the crappy pics. I was anxious to drive it.
2005 Toyota Tacoma DC 4x4 4.0L TRD Off-Road
2008 Yamaha Zuma YW 50
2015 GMC 2500 Denali HD 4x4 Duramax/Allison Black on Black
2016 Grand Design Momentum M-Class 350M Toy Hauler
2019 Ranger RB190 Bay
2019 Yamaha UMAX 1
Black HD is offline
post #40 of 54 (permalink) Old 05-08-2019, 08:55 PM Thread Starter
UTEngineer's Avatar
Looks good ... and no more “trumpet” looking stock exhaust spewing hot exhaust fumes at your trailer during regen. 😉
Similar Threads
WAY Way Way new LI66CrewCab4MNTK Introductions 14 03-06-2015 09:13 AM
7 way to 4 way trailer wiring cattlehauler Towing & Hauling 10 07-14-2010 11:52 AM
Is the a way to help injectors that are on there way out. need to do under warranty 04heavychevy Maintenance 2 04-24-2010 10:47 PM
7 Way Round To A 4-Way Flat LED mojo0107 Towing & Hauling 4 11-22-2008 08:22 PM
