2018 L5p Lower oil pan leak question? - Chevy and GMC Duramax Diesel Forum
2017-19 GM T-K2 Platform Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
post #1 of 6 (permalink) Old 12-05-2019, 05:18 PM Thread Starter
Mine was leaking and the dealership fixed it today. They told me they had to lower the front driveshaft/differential to do so? When i got home and inspected work it looks like i might be missing a nut or either they put the bolt back in backwards. See picture for area circled in red. If you zoom in you can see where either a nut has scared the metal or either they installed the bolt backwards? Can anyone check theirs and post a pic or let me know? Thanks!
sthomasIV is offline
post #2 of 6 (permalink) Old 12-05-2019, 07:17 PM Thread Starter
Picture taken from passenger side looking toward front of truck with lower oil pan on right hand side
post #3 of 6 (permalink) Old 12-05-2019, 07:37 PM
NHfireDmax's Avatar
Thats normal... threaded from top down...
Thought the same thing briefly while doing my lift kit...
2019 Quartz Red Denali HD Chrome deleted
NHfireDmax is offline
post #4 of 6 (permalink) Old 12-30-2019, 03:48 PM
I'm chasing an oil leak on mine and discovered the same thing! I'm greatly relieved to know the differential isn't loose on it's moorings! Thanks for clarifying!
Now to the oil leak- Steering column is wet, I've noticed occasional smoke emitting from under the hood and while now changing the oil, the underside is quite wet. Gonna search this forum for similar reports. The truck's a 2017 with now only 33K on the odometer. I also had ALL injectors changed at 7K miles due to a reported bad batch of injectors from the supplier. Wonder what's involved in the injector swap that may have precipitated the oil leak?
Mablehead is offline
post #5 of 6 (permalink) Old 01-04-2020, 07:24 AM
DmaxBill's Avatar
Hi, My lower oil pan was just replaced at 11,000 miles do to leaking.When I first noticed the leak around the bottom of the bell housing I found all the bolts on the oil pan were loose. I tightened them thinking this would help seal the gasket. 2 weeks later it was still leaking to I took it in to the dealer and was told there is no gasket used on the oil pan only rtv silicone and once it starts leaking GM requires the pan to be replaced. I have about 500 miles on it since the repair so we'll see what happens.
2018 GMC Denali 3500 L5P White Frost Metalic
DmaxBill is offline
post #6 of 6 (permalink) Old 01-16-2020, 11:12 AM
hvtexskeeter's Avatar
Gonna have to take a look! No drips on the garage floor but who knows!
hvtexskeeter is offline
