At my whits end!!! Need help please!!! - Chevy and GMC Duramax Diesel Forum
2017-19 GM T-K2 Platform Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
post #1 of 5 (permalink) Old 01-18-2020, 07:45 AM Thread Starter
Bigshock82's Avatar
I have a 2017 Silverado 2500 that has been having nothing but problems with glow plugs going bad So far I have had #8 go bad 3 times and 4 other cylinders as well. The update was done to module etc. Before I get rid of this Lemon can anyone shed some light on this. I love this truck it does everything I need for out family adventures etc. Gm is giving me the run around. Please help thank in advance.
Bigshock82 is offline
post #2 of 5 (permalink) Old 01-18-2020, 08:59 AM
407driver's Avatar
What plugs are you putting in the truck?
Also take your truck and have both batteries load tested. They have to be disconnected and tested separately.
There seems to be a correlation between batteries getting low and GPs failing. If either battery is low, replace them BOTH!
407driver is online now
post #3 of 5 (permalink) Old 01-18-2020, 10:34 AM
redwngr's Avatar
Have the connectors in the harness to the glowplugs been checked?
Several threads/pictures available.
Might not be the plugs that are bad.
Still under 100,000 miles?
What's the dealer say?
redwngr is offline
post #4 of 5 (permalink) Old 01-18-2020, 10:48 AM
Dmax affair's Avatar
What redwngr said, what does the dealer say about this? Might be time to see a different dealer.
I would suspect the control module, I have owned Duramax trucks since 2003 and have never replaced a glow plug.
2018 GMC Denali 3500 SRW CC SB 4x4 D/A in Frost white.
2015.5 GMC Denali 3500 SRW CC SB 4x4 D/A in Summit white. Traded
2013 Cadillac CTS-V Black Raven coupe 6mt.
2012 Chevrolet Silverado LTZ 3500 SRW CC SB 4x4 D/A in Graystone metallic. Traded
2003 GMC SLE 2500 CC SB 4x4 D/A in Summit white. SOLD
Dmax affair is offline
post #5 of 5 (permalink) Old 01-18-2020, 01:19 PM Thread Starter
Bigshock82's Avatar
407drive I would assume the dealer is using GM glow plugs since they are under warranty. Truck only has 40,300 miles on it. I will recommend them checking the batteries Tuesday when I take it back. I have several friends with L5P's and we all go to same dealership. I honestly think this truck is a Lemon. Always had something wrong with its since 1st month I owned it. I am original owner as well. Been slowly loosing coolant and can seem to find a leak. It hold the pressure test and all Dry underneath but there is the Dexcool smell under the hood. Thanks for your reply.
