Coolant level - Chevy and GMC Duramax Diesel Forum
2017-19 GM T-K2 Platform Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
 6Likes
post #1 of 21 (permalink) Old 10-06-2018, 10:55 AM Thread Starter
Coolant level
My coolant level slowly goes down and I continually have to add coolant for it to be at the proper level, is this normal? Over the time I have owned this truck(1 year and 6 months) I have used almost a entire gallon of coolant. Also would it be bad if I filled the overflow reservoir almost all the way to the top? Would it blow coolant out everywhere?
Sent from my iPhone using Tapatalk Pro
1thackattack is offline
post #2 of 21 (permalink) Old 10-06-2018, 11:53 AM
[ Would it blow coolant out everywhere?
shouldn't hurt just will come out the overflow
2018 Duramax L5P CCLB High Country 3500
dadnjesse is offline
post #3 of 21 (permalink) Old 10-06-2018, 12:14 PM
Funny, as I just had coolant level low come up on dash this a.m. it was damn near full but I added a cup or so. Hoping it was just an air bubble. I have no leaks or drips in my clean concrete driveway. Time will tell
Sent from my SM-G930T using Tapatalk
oneshotkyle is offline
post #4 of 21 (permalink) Old 10-06-2018, 02:36 PM
Took mine to dealer for low coolant light. They advised improper filling from factory. They burped and topped system off.
oneshotkyle likes this.
Afflicted is offline
post #5 of 21 (permalink) Old 10-06-2018, 03:26 PM
No, not normal nor OK. Take it to dealer if under warranty.
407driver likes this.
Ron Nielson
Ron Nielson is offline
post #6 of 21 (permalink) Old 10-07-2018, 08:34 AM
407driver's Avatar
What Ron said. A 2017 vehicle should still be under factory warranty, USE IT!!
407driver is offline
post #7 of 21 (permalink) Old 10-09-2018, 11:59 PM
mts6175's Avatar
Mine is in there right now for the same thing and it's my water pump.
2017 GMC 2500 Denali HD|Southern Trucks 2" Level|Fox 2.0's|285/65r20's|Retrax ProMX
mts6175 is offline
post #8 of 21 (permalink) Old 10-10-2018, 07:25 AM
Jimc295's Avatar
I've got the same issue. When I purchased the truck a couple of months ago the shop put a pressure test on it and it held for 8 hours. SO I was thinking maybe water pump, not to sure about the WP but the engine only has about 30K on it so to early for a WP failure (could be the old WP on the new motor which was replaced under warranty) in my book so am watching it for now.
2015 Silverado 3500HD 4x4 LTZ 40 inch donaldson cat back exhaust
2007.5 Ram 2500 Sold
Jimc295 is offline
post #9 of 21 (permalink) Old 10-10-2018, 06:50 PM
mts6175's Avatar
Mine has 34000 miles on it, so sounds like it's an issue.
mts6175 is offline
post #10 of 21 (permalink) Old 10-12-2018, 12:35 AM
Mine has been coming on for the last week. I don't tink this is normal, but my dealer says nothing is wrong. I also still have the surging issue, and they state nothing wrong. Even a small amount of coolnat loss is not normal, although I also have a 2014 Mercedes that does the same thing. So, with today's engines, is this the new normal? Topping off the fluid every so often?
Edit 11/30/19
2020 CC SRW GMC AT4 Carbon Black Metallic- Love the new truck.
HEEP is offline
