Manual regen - Chevy and GMC Duramax Diesel Forum
2017-19 GM T-K2 Platform Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
post #1 of 5 (permalink) Old 05-01-2019, 03:43 PM Thread Starter
Manual regen
So my truck decided to go into regen mode right when I got home, so I used my edge cts2 to do a manual regen just for kicks and giggles to see what it was like(donít think the elderly neighbors liked it to much). Anyways it said that afterwards a oil change may be necessary, is that true? I have 78% oil life and I run mobil one synthetic. Just curious under what circumstances that a oil change afterwards would be required.
Sent from my iPhone using Tapatalk Pro
1thackattack is offline
post #2 of 5 (permalink) Old 05-02-2019, 07:56 AM
wq93's Avatar
A stationary regen gets everything extremely hot even compared to a normal regen where you have plenty of forced air cooling throughout the engine compartment. I suspect GM feels the temperature generated during a stationary regen may degrade the oil sufficiently to require a change.
When GM introduced "camel mode" (allows the engine to safely run at reduced power after cooling system failure by alternating cylinder banks) for some of the Cadillac engines a number of years ago once camel mode was engage the change oil message automatically popped up.
I wouldn't run a stationary regen unless absolutely necessary (as in DPF couldn't clean itself in normal operation thus requiring a forced stationary regen to clear the codes and reduced performance restrictions).
2018 2500HD Denali
sold: 2006 Sierra 2500HD LBZ, 2001 Sierra 2500HD LB7
wq93 is offline
post #3 of 5 (permalink) Old 05-02-2019, 09:44 AM
I usually run a manual monthly on my work diesels. Have had problems with the DPF in the past and the dealer suggested once a month. When I run it manually, it seems to do a significantly better job of cleaning as there is white smoke and the tailpipe gets roasting hot. I do not do any oil changes afterwards. If you monitor the engine temps it does not run any hotter during a regen so I assume it is not doing anything bad to the oil.
2017 Sierra 2500HD Denali Dmax
2011 Silverado 3500HD Dually Dmax
Trucklover63 is offline
post #4 of 5 (permalink) Old 10-17-2019, 09:43 AM
If anyone is curious and wants to watch a really dull video, I did a manual Regen on my stock LML with the Edge Insight CTS2 this A.M. to get a baseline for how often the DPF needs to get cleaned under "normal" (for me) driving using Opti- Lube XPD.
So just for fun, if you go to this channel, you will see three vids. And yes, it is scary the first time you do it.
And have one of these handy.
2015.5 GMC Denali HD LML 6.6' bed CC SRW
EMISSIONS ON, Resonator delete, PCV relocation, AFE Rear Diff Cover, 34.5" Toyo AT2 Tires, Bilstein Shocks, FASS 95gph/ lowered PSI lift pump, Exergy Fuel System Saver, Dirty Hooker Diesel Line Pressure Modifier, Edge Insight CTS2 Monitor
LMLMAO is offline
post #5 of 5 (permalink) Old 10-17-2019, 09:45 AM
https://www.youtube.com/results?search_query=lml+mao
I forgot the video link!
LMLMAO is offline
Similar Threads
Manual Regen idamainer 11-16 LML Duramax Powertrain 48 07-28-2018 05:34 PM
Manual regen code drmisherre 07.5-10 LMM Performance Parts Discussion 1 12-09-2014 01:56 PM
Manual regen Tetonhawk 11-16 LML Duramax Powertrain 56 04-17-2014 12:05 PM
Manual Regen Without DPF Possible? PTOWNLMM 07.5-10 LMM Duramax Powertrain 8 09-18-2010 11:44 AM
DPF Manual Regen Switch and DPF lifespan? newduramax30 07.5-10 LMM Duramax Powertrain 8 11-15-2009 06:33 PM
